Connecting tiles / templates to existing Blynk dashboards
The tiles / templates widget seems like a great way to wrangle several projects together into a single dashboard. However, I was frustrated to find that when selecting a device, the only option available is a new project. Couldn’t you allow it to reference existing Blynk dashboards, as well?
Device tiles is a list of devices, not projects. For that, it serves it’s purpose.
Project - list of tiles - device tile - device dashboard
You are referring to some kind of a new widget, but I’m not sure how it’s different from Blynk app itself, containing all your projects…
Thanks, @Pavlo
My mistake. I thought the tiles were intended to give quick access to widgets from multiple dashboards. On further inspection, I see that they make possible the control of multiple devices of different types from a single dashboard, and offer an alternative presentation layer for existing widget types. That’s some impressive work!
The “new kind of widget” that I described would use that alternative presentation layer as a way to quickly access information and controls across several dashboards - sort of a meta-dashboard. For example, currently, if I want to switch between my thermostat and automated blinds dashboards, I have to tap the dashboard switcher icon, swipe…swipe…swipe, select the blinds dashboard, and finally, I can tap the switch to lower the blinds.
In a perfect world, I would have had the foresight to build all of my home automation projects on a single dashboard, and the current implementation of tiles would provide that shortcut between projects. However, the early Blynk dashboard was a single page, no tabs, no scrolling, no scalable widgets, and no tiles; so each project (blinds, lights, thermostat, etc.) really needed its own dashboard.
So I guess you could add the meta-dashboard / multi-project-tiles to my Blynk wish list. :slight_smile:
Well, from your description, Device Tiles is a perfect fit for everything you described.
Thermostat will be a Level Tile
Blinds can be a Level or Button Tile.
You should really consider trying it out as a home dashboard.
Yes, it would be perfect. The downside is that I’d have to reprogram all of my devices. :stuck_out_tongue:
Evolution doesn’t stand still. Things should evolve :slight_smile:
