Fellow Blynkers,
I am struggling with a Python code.
After learning about Raspberry (hardware, install etc.) I managed to make a headless connection and attach servos to my Sparkfun Pi Servo Phat(2). Then I spend a lott of time learning Python so that I can move the servos on command. I bought a pan/tilt bracket that uses 2 servos.
Recently, I came acros Blynk. It is a very cool tool! I managed to make simple commands between the app and my configuration.
But, now that I saw a video I am stuck. https://stemship.com/raspberry-pi-camera-control/
So far I could learn the basics / tutorials to enhance my knowledge. The video shows how somebody uses an joystick button to move the bracket (included 2 servos) around. The joystick code is totally different from what I worked with so far. Right know I am even struggling with the standard writings of the code. It has stressed me out because it seems that this script was written by someone with extensive knowledge of Python.
Code:
from adafruit_servokit import ServoKit
kit = ServoKit(channels=16)
angleX = 0
angleY = 0
kit.servo[3].angle = 90
kit.servo[2].angle = 90
import BlynkLib
from BlynkTimer import BlynkTimer
timer = BlynkTimer()
def limit(value, lower, upper):
if value < lower:
value = lower
elif value > upper:
value = upper
return value
@blynk.on("V1") # Joystick
def v1_write_handler(value):
global joystick_mode, angleX, angleY
joystickX = int(value[0])
joystickY = int(value[1])
# PanTilt
if joystickX > 30: angleX = 4
elif joystickX < -30: angleX = -4
else: angleX = 0
if joystickY > 30: angleY = 4
elif joystickY < -30: angleY = -4
else: angleY = 0
print("angle {} {} ".format(angleX,angleY))
def panTiltMove():
global angleX, angleY
kit.servo[3].angle = limit(kit.servo[3].angle - angleX, 45, 135)
kit.servo[2].angle = limit(kit.servo[2].angle - angleY, 45, 135)
# Define Timers
timer.set_interval(0.1, panTiltMove) # 100ms
while True:
blynk.run()
timer.run()```
Can someone please have a look and help / guide me in the right direction? I keep on getting a error after: @blynk.on("V1") # Joystick. Error> @Blynk.on("V1) , TypeError: on() missing 1 required positional argument: (func). So far, I have not encountered this error before. I do not know where to start...
Extra> I also found this code, but this looks even more complicated. However, this code seems to add a active control for activating the virtual pins.
```BLYNK_AUTH = 'YourAuthToken'
from board import SCL, SDA
import busio
from adafruit_pca9685 import PCA9685
i2c_bus = busio.I2C(SCL, SDA)
pca = PCA9685(i2c_bus)
pca.frequency = 60
kit = ServoKit(channels=8)
joystick_mode = 0 # 0:Motor 1:PanTilt
angleX = 0
angleY = 0
import BlynkLib
import os
import math
if value < lower:
value = lower
elif value > upper:
value = upper
return value
@blynk.on("connected")
def blynk_connected():
blynk.sync_virtual(2, 4)
blynk.virtual_write(3, 1)
# PanTilt
if joystick_mode:
else: angleX = 0
else: angleY = 0
# Motor
else:
joystickY = joystickY * 0.7
if joystickY >= 0:
if joystickX >= 0:
throttleL = joystickY + joystickX * 0.3
throttleR = -joystickY + joystickX
else:
throttleR = -joystickY + joystickX * 0.3
elif joystickX >= 0:
throttleL = joystickY - joystickX * 0.3
throttleR = -joystickY - joystickX
else:
throttleR = -joystickY - joystickX * 0.3
kit.continuous_servo[0].throttle = throttleL / 100
kit.continuous_servo[1].throttle = throttleR / 100
@blynk.on("V2") # Motor and Pan/Tilt switch button
def v2_write_handler(value):
joystick_mode = int(value[0])
if joystick_mode == 0: # Motor
kit.servo[6].angle = 90
kit.servo[7].angle = 110
@blynk.on("V3") # Power button
def v3_write_handler(value):
if int(value[0]) == 0: # Off
os.system('sudo shutdown -h now')
@blynk.on("V4") # LED ON/OFF button
def v4_write_handler(value):
if int(value[0]): # ON
pca.channels[14].duty_cycle = 0xffff
pca.channels[15].duty_cycle = 0xffff
else: # OFF
pca.channels[14].duty_cycle = 0x0000
pca.channels[15].duty_cycle = 0x0000
def panTiltMove():
kit.servo[6].angle = limit(kit.servo[6].angle - angleX, 0, 180)
kit.servo[7].angle = limit(kit.servo[7].angle - angleY, 0, 180)
# Define Timers
while True:
blynk.run()
timer.run()```
This code gives me the same error after: @blynk.on("connected")
I think it has somethin to do with @Blynk.on. in both scripts.
In great expectation!!!
