I downloaded the app, signed up and got the auth token
I also downloaded the library and imported it
I have a arduino uno connected over usb to my computer but which example do i have to use???
Hi. Thank you for your question.
Arduino library supports different shields to connect to internet. From your description, I understand that you have USB connection only, so this would be BoardsAndShields -> Arduino_Serial_USB example.
Let me know if you have any other connectivity, other than USB (Serial).
Hope this helps!
Iām getting the same issues.
Hi
thanks for your answer
I have tried it with your example,but it worked neither.
So i tryed it with my ethernet shield
But i open the ethernet example
Then i put my token where mytoken is
char auth[] = āmytokenā;
then i upload it an press play in the app.
then it says Arduino uno is offline.
this message is most probably saying either you didnāt put correct auth token, either it is outdated, please check carefully token on dashboard is corresponds to those one you uploaded to board.
Thanks for your great support
Iāll try this and will give you feedback later on
@vshymanskyy
Now it works with my Ethernet Shield
Everything Works perfectly
But i have another question
If i use the Graph that Shows the Data of my Temperature sensor it only Shows a number between 0 and 1023
but i want that value shown as a temperature in Celsius
I think i have to Change the code for that so could you please give me an example how this code may Look like?
Iām trying to connect over USB but keep getting the below and the app says my UNO in not in network. Iāve unpluged the UNO, closed/reopened Arduino IDE but still no luck.
Any ideas?
Connecting device at COM6 to cloud.blynk.cc:8442...
OpenC0C("\\.\COM6", baud=9600, data=8, parity=no, stop=1) - OK
Connect("cloud.blynk.cc", "8442") - OK
InOut() START
DSR is OFF
Received EOF
EVENT_CLOSE
InOut() - STOP
Disconnect() - OK
InOut() START
DSR is OFF
Received EOF
EVENT_CLOSE
InOut() - STOP
Disconnect() - OK
InOut() START
DSR is OFF
Received EOF
EVENT_CLOSE
InOut() - STOP
Disconnect() - OK
InOut() START
DSR is OFF
@xc0de,
This should workā¦
Please try pressing reset button on Arduino, then launching the script, and releasing a reset button.
Anyone else having same issue on Windows?
I had the same issue.
Your workaround worked for me.
After uploading a new sketch (via USB), I have to reset my arduino, start the com2tcp script, and then reset my arduino again. After that the connection works.
Greetz, Geert.
То же ŃŠ°Š¼Š¾Šµ windows 7
i followed all the instructions, download the library and upload the Arduino_Serial_USB, and double check the token, and still saying the same, āyour arduino UNO is not in networkā, and in the script i write --help and it try to conect over and over again, iāve already expend 2 hours in this and iāve no idea
@CRheyd, In most cases you donāt need to modify the script, just specify the PORT of Arduino, when you run it.
Please provide output of the script and Arduino (if you have it), so we can investigate your problem.
Thanks!
Sorry, new users can not upload images (seriously ?
i upload the sketch to my arduino, and then open the script it already say COM7, and in the IDE of arduino it says COM7 too, so itās the same, and in the app it said the same āyour arduino UNO is not in networkā
It also could be a case when auth_token in sketch doesnāt correspond to those one in active dashboard. Please double check this.
Stupid question maybe,⦠but did you run the script ?
I mean: Not just āopenā it but run it (as a programm)
I forgot on first try and got a āArduino is offlineā error untill i did what had to be dun ⦠
i was actually running it as a programm and it didnāt work
then i try to open it (instead of run it) and i edit it in the bloc of notes, change the default COM port, to the port that my arduino usually has, save and close, and then it work just fine
