Can i get the sketch and connections for this?
Curious. Why would one use a UNO+ESP8266 when we have the ESP8266 and ESP32 which can run arduino code directly? No of pins? ESP8266 may fall short but the ESP32 has pins aplenty. Costs much lower than the Uno.
Yes, search this forum of keywords like ESP-01, ESP in AT mode, ESP as shield, etc.
There are lots of topics, with answers to every conceivable question about this process
Please READ through all of them. but ask your questions here, in your own topic.
Also some info hereā¦
http://help.blynk.cc/how-to-connect-different-hardware-with-blynk/arduino/esp8266-with-at-firmware
Welcome, and happy Blynking!!
@mohan_sundaram Why would anyone ride a bike when there are perfectly good cars, or own a dog when cats are superior
and so on⦠Often it is all one knows about, has, or needs at the time.
There is nothing wrong with using Arduino and ESP⦠a bit of effort and understanding on the users part to connect and properly utilise, but the same can be said for many sensors, motors, displays, etc.
I agree and believe it is to do with familiarity. Am trying to understand in which usage/tech need scenarios that combo of Uno+ESP8266 would be preferred. Given that folks would be familiar with Arduino code and ESP8266/32 would run those with minor mods, I asked that question. Am looking to learn and not criticise a choice.
You are right, sorry for my assumption that you were following in others footsteps ![]()
Well, even the lowly UNO has more I/O, particularly Analog in, then many ESP8266 dev boards. And the MEGA⦠well, mega more ![]()
Many older sensors are still 5v and even 3.3v sensors work without any efforts on base Arduinos.
Many UNO compatible shields out there that can be used with Blynk
Even without using an ESP as shield, the lowly UNO can be used with Blynk (via USB) for non mobileised uses and still have room for a shield⦠all without taking up any otherwise elsewhere needed WiFi boards.
Bike v Car
Bike is much cheaper, better for your health but slower.
If you have a mega project to build a Mega might be useful but it will not be a true IOT project.
ESP v Arduino + nightmare dongle.
ESP is cheaper, faster, easier to use and allows you build IOT projects.
Chronic Fatigue = not safe to use bike for now (AKA, what works for some, will not work for all)
Bin dar dun dat⦠and IS true IoT as I can control everything on it over the internet and across the world
(assuming I ever leave the house first) ![]()
Two crossed wires, power & ground, NO soldering⦠even you can do it ![]()
I had like 6 Arduinos and 0 ESPs when I started with Blynk, and yet I made IoT projects quickly, easily and NO new expense (aside from what I already had).
Round 2? ![]()
@Costas I know you like yanking my chain on this⦠ditto here
But honestly, I still use my Arduinos, and they still have purpose. Does that mean I am anti ESPā¦NOT A CHANCE⦠I fully intend to use them going forward. But this ongoing debate is about those who, like me, may not have a choice yet.
I fully intend to help those as they try⦠i just donāt want to keep repeating myself repeatedly each and every time⦠so I encourage them to search for the info, not bail out because of peer pressure.
An IOT project is one that adapts as technology changes i.e. WAN firmware updates etc.
If you want to build a fixed project at higher cost use an Arduino + nightmare dongle.
If you want to build a flexible IOT project use a low cost ESP.
If you want to learn, use what you have and focus on the challenge⦠if you want the easy way out, buy new and beg for assistance⦠see where that gets you
PS since when does Internet of Things mean you canāt use older technology⦠My 16Mhz MEGA is doing more simultaneous Blynk stuff then the average ESP-only project in this forum⦠and will even work on battery if I want it to
Cost me $0 at the time I started Blynk⦠well⦠there was that time I purchased energy for my Local Server
Blynk has just released an awesome new widget.
You have code on your Mega for me to flash new firmware, from here, to use this new widget?
No, thatās why IOT projects use ESPās.
My dad uses a tractor to clean out his barn, not his 3/4 ton dually pickup⦠that he uses for the trailers⦠not his car⦠that he uses for going to town to pick up parts for the tractor
Eanc of those is a vehicle of some sort and each has benefits/disadvantages over the others⦠doesnātā make one better than the other for a Farming of Land project⦠why should an MCU make/model/connection type matter to IoT
It is NOT called IoESP
Hey, again!? An (already) ancient topic for discussion, but⦠why not? ![]()
As for me, the answer is simply: Because I could to do so. A toy? Why not? Adults needs toys as well, especially adult boys
Could I use the ESP in this particular project? Sure! But a Blynk was just an addition to already working toy (or āprojectā as I prefer to call it anyway)
Well, there is one that Iām aware. Interrupts and timers are sometimes very important in some specific tasks. And it seems the AVR processors are far better documented in this aspect then ESP. Not to mention itās hardware capabilities. Can we use the only hardware timer of ESP8266 in Arduino IDE? If so, I donāt know how. The software PWM is a bit like software Serial port. It works, but it is not a real thing. That said, I still prefer using ESPās in IOT things, but it doesnāt mean I gonna forget about AVRās
And one more! Using Blynk in destinations, where no WiFi is available at all. Here comes the AVR + GSM combo. And it is very similar in many terms to AVR +ESP, but that is a different story.
Forget FOL, this is an IOT site.
@ashish_pandey what made you think adding an ESP to an Arduino would be a good idea? Does your project need an Arduino as the vast majority of projects donāt.
Some people like sticking pins in their eyes but itās not really for me.
Me too.
Add GSM module to the ESP.
So⦠thatās a no to you writing that prefect farming code for me
Oh wellā¦
Actually I think my viewpoints put āpinsā in your eyes more then mine
Sorry ![]()
And me as well⦠I just also like using ALL of my stuff however I want to ![]()
Heavens forbid⦠a nightmare dongle suggestion from @Costas ⦠say it isnāt so ![]()
Actually, I want to get a GSM module one of these days⦠but then there is the data fees, etc⦠and no real need, I just like learning new hardware
And what s creature is that? I wouldnāt do that. Or at least put a sticker on it: Build at your own risk.
Well, I try to protect my eyes the best I can, but there are many more holes⦠And why not? As a way to explore new territories⦠In IOT world? ![]()
@Costas You do know that while we both have our firm beliefs, all this is in fun
But I think if we debate this on every new ESP & Arduino topic, perhaps new users will switch over BEFORE they dare ask directions for such
We should come up with a debate for all āNeed Help Soonestā and āGive me codeā requests
All are talking just out of topic. I asked how can i connect my ESP8266 module to Arduino and Blynk
And I asked:
You started with:
Developers spent a huge amount of time providing this information rather than developing the project.
