I am trying to connect my Arduino based Controllino Maxi Automation Industrial PLC to the Blynk app, but I am getting this message in the Serial Monitor:
[486767] Connecting to blynk-cloud.com:80
There is no actual connection between them. This is my first time trying this, can anyone assist me?
The Controllino has an Ethernet Port which utilizes a Ethernet WIZnet Chip W5100. The code i used is from the example sketch.
Social networks: http://www.fb.com/blynkapp
http://twitter.com/blynk_app
This example shows how to use Arduino Ethernet shield (W5100)
to connect your project to Blynk.
NOTE: Pins 10, 11, 12 and 13 are reserved for Ethernet module.
DON'T use them in your sketch directly!
WARNING: If you have an SD card, you may need to disable it
by setting pin 4 to HIGH. Read more here:
https://www.arduino.cc/en/Main/ArduinoEthernetShield
#include <Ethernet.h>
char auth[] = "I Put my authentication token code here";
#define W5100_CS 10
#define SDCARD_CS 4
pinMode(SDCARD_CS, OUTPUT);
digitalWrite(SDCARD_CS, HIGH); // Deselect the SD card
Blynk.begin(auth);
//Blynk.begin(auth, "blynk-cloud.com", 80);
//Blynk.begin(auth, IPAddress(192,168,1,100), 8080);
// For more options, see Boards_Ethernet/Arduino_Ethernet_Manual example
