Hi, i have some error with my project that my project connect to the internet but it’s not show temp or humid on value only work with notification and can send email on code
This is my code.
boolean buttonState;
boolean lastState;
boolean state = HIGH;
int ledPin = 8;
int a;
#include <EEPROM.h>
#include “IRremote.h”
int receiver = 11;
IRrecv irrecv(receiver); // create instance of ‘irrecv’
decode_results results;
//-------------blynk-----------------
SoftwareSerial SwSerial(26, 28); // RX, TX
#define BLYNK_PRINT SwSerial
#include <BlynkSimpleSerial.h>
char auth[] = "b4c8c77819424f40acb697bdbaf0378e";
#include "DHT.h"
DHT dht;
#include <DS3231.h>
DS3231 clock;
RTCDateTime dt;
#include <Wire.h>
#include <LCD.h>
#define I2C_ADDR 0x27 // กำหนดตำแหน่ง Address ของ I2C
// #define I2C_ADDR 0x3F // ในบางกรณี Address ของ I2C เป็น 0x3f
#define BACKLIGHT_PIN 3
LiquidCrystal_I2C lcd(I2C_ADDR,2,1,0,4,5,6,7);
#include <SD.h>
#include "Wire.h"
#include "SPI.h"
File myFile;
const int chipSelect = 4;
byte p20[8] = {
B10000,
B10000,
B10000,
B10000,
B10000,
B10000,
B10000,
B10000
byte p40[8] = {
B11000,
B11000,
B11000,
B11000,
B11000,
B11000,
B11000,
B11000
byte p60[8] = {
B11100,
B11100,
B11100,
B11100,
B11100,
B11100,
B11100,
B11100
byte p80[8] = {
B11110,
B11110,
B11110,
B11110,
B11110,
B11110,
B11110,
B11110
byte p100[8] = {
B11111,
B11111,
B11111,
B11111,
B11111,
B11111,
B11111,
B11111
int relay1 = 47;
int relay2 = 49;
int relay3 = 51;
int relay4 = 53;
int inrec = 11;
int inemit = 3;
void sendUptime()
delay(dht.getMinimumSamplingPeriod());
float humidity = dht.getHumidity(); // ดึงค่าความชื้น
float temperature = dht.getTemperature(); // ดึงค่าอุณหภูมิ
Blynk.virtualWrite(V11, humidity );
Blynk.virtualWrite(V10, temperature );
if(temperature>32){
Blynk.email("ketsayay@gmail.com", "Over heat!!!", "Temperature Over 32C now");
//---------------------------end temp blynk---------------------------------------
while (!Serial) {
//-----------------set up clock----------------------
clock.begin();
clock.armAlarm1(false);
clock.clearAlarm1();
clock.armAlarm2(false);
clock.clearAlarm2();
//clock.setAlarm1(0, 0, 0, 20, DS3231_MATCH_S);
clock.setAlarm2(0, 0, 0, DS3231_EVERY_MINUTE);
checkAlarms();
// ---------------------blynk---------------------------
timer.setInterval(5000L, sendUptime);
// SwSerial.begin(9600);
Blynk.begin(auth);
// Wait until connected
Blynk.email("ketsayay@gmail.com", "Room 510 Start", "Room 510 connected.");
Blynk.notify("Connected Room 510");
irrecv.enableIRIn();
Wire.begin();
SPI.begin();
lcd.begin (20,4);
lcd.setBacklightPin(BACKLIGHT_PIN,POSITIVE);
lcd.setBacklight(HIGH);
lcd.setCursor(1,1);
lcd.print("Loading in Progress");
lcd.createChar(0, p20);
lcd.createChar(1, p40);
lcd.createChar(2, p60);
lcd.createChar(3, p80);
lcd.createChar(4, p100);
delay(2000);
progressbar();
lcd.clear();
delay(500);
// lcd.setCursor(1,0);
// lcd.print("Welcome ALL");
pinMode(relay1,OUTPUT);
pinMode(relay2,OUTPUT);
pinMode(relay3,OUTPUT);
pinMode(relay4,OUTPUT);
Serial.begin(57600);
Serial.println();
Serial.println("Status\tHumidity (%)\tTemperature (C)\t(F)");
dht.setup(12); // data pin 2
/// sd card
lcd.setCursor(1,0);
lcd.print(F("Checking SD card..."));
if (!SD.begin(chipSelect)) {
lcd.setCursor(2,2);
lcd.print(F("Card Not Found :("));
lcd.setCursor(0,3);
lcd.print(F("Please Check SD card"));
lcd.clear();
return;
lcd.setCursor(5,1);
lcd.print(F("card Found"));
openfile();
delay(500);
lcd.clear();
{ // ---------------------blynk---------------------------
time();
alarm();
//---------------Dht 22---------------------------
Serial.print(dht.getStatusString());
Serial.print("\t");
Serial.print(humidity, 1);
Serial.print("\t\t");
Serial.print(temperature, 1);
Serial.println(dht.toFahrenheit(temperature), 1);
lcd.setCursor(1,1);
lcd.print("Temp=");
lcd.setCursor(6,1);
lcd.print(temperature,0);
lcd.setCursor(8,1);
lcd.print("C");
lcd.setCursor(10,1);
lcd.print("Humid=");
lcd.setCursor(16,1);
lcd.print(humidity,0);
lcd.setCursor(18,1);
lcd.print("%");
if (irrecv.decode(&results)) // have we received an IR signal?
translateIR();
irrecv.resume(); // receive the next value
//-----------------------------bylnk----------------------------------
BLYNK_WRITE(V1) //Button Widget is writing to pin V1
int pinData = param.asInt();
if(pinData==1){
digitalWrite(relay1,HIGH);
logv1on();
else if(pinData==0)
digitalWrite(relay1,LOW);
logv1off();
BLYNK_WRITE(V2) //Button Widget is writing to pin V1
if(pinData==1){
digitalWrite(relay2,HIGH);
logv2on();
else if(pinData==0)
digitalWrite(relay2,LOW);
logv2off();
BLYNK_WRITE(V3) //Button Widget is writing to pin V1
if(pinData==1){
digitalWrite(relay3,HIGH);
logv3on();
else if(pinData==0)
digitalWrite(relay3,LOW);
logv3off();
BLYNK_WRITE(V4) //Button Widget is writing to pin V1
if(pinData==1){
digitalWrite(relay4,HIGH);
logv4on();
else if(pinData==0)
digitalWrite(relay4,LOW);
logv4off();
BLYNK_WRITE(V5) //Button Widget is writing to pin V1
if(pinData==1){
logv5on();
else if(pinData==0)
logv5off();
void progressbar(){
lcd.setCursor(1,2);
lcd.print(F(" "));
for (int i = 0; i<20; i++)
for (int j=0; j<5; j++)
lcd.setCursor(i, 2);
lcd.write(j);
delay(50);
void time(){
dt = clock.getDateTime();
lcd.setCursor(1,0);
lcd.print(clock.dateFormat("d-m-Y H:i:s", dt));
void openfile()
myFile = SD.open("LogN.csv", FILE_WRITE); // ความถี่
myFile.print(",");
myFile.print(",");
myFile.print(",");
myFile.print("File Open on");
myFile.print(",");
myFile.print(clock.dateFormat("d-m-Y H:i:s", dt));
myFile.print(",");
myFile.println(" ");
myFile.print("Date-Time");
myFile.print(",");
myFile.print("Temperature");
myFile.print(",");
myFile.print("Humidity");
myFile.print(",");
myFile.println("Light");
myFile.close();
lcd.setCursor(2,2);
lcd.print("Created LogN.csv");
myFile = SD.open("Switch.csv", FILE_WRITE);
myFile.print(",");
myFile.print(",");
myFile.print(",");
myFile.print(",");
myFile.print(",");
myFile.print(",");
myFile.print("Switch1");
myFile.print(",");
myFile.print("Switch2");
myFile.print(",");
myFile.print("Switch3");
myFile.print(",");
myFile.print("Switch4");
myFile.print(",");
myFile.print(",");
myFile.print(",");
myFile.close();
lcd.setCursor(2,3);
lcd.print("Created Switch.csv");
lcd.clear();
//----------------------------------------บันทึก ค่า temp humid light ทุก 1 นาที-------------
void timestamp(){
myFile.print(",");
myFile.print(temperature);
myFile.print(",");
myFile.print(humidity);
myFile.print(",");
myFile.println("---");
myFile.close();
Serial.print("Save Sucessed !!");
void stampRS1(){
int r1;
r1= EEPROM.read(1);
if (r1==1){
EEPROM.write(1,0);
r1=a;
else if (r1=0){
EEPROM.write(1,1);
r1=a;
buttonState = a; //digitalRead(buttonPin);
if ( ( buttonState == LOW) && (lastState == HIGH) ) state = !state;
digitalWrite(ledPin,state);
lastState = buttonState;
myFile.print(",");
myFile.print("Remote");
myFile.print(",");
myFile.print("---");
myFile.print(",");
myFile.print(",");
myFile.print(",");
myFile.print(",");
myFile.print(",");
// ใส่ค่า LDR myFile.printIn(" ");
myFile.close();
void stampRS2(){
myFile.print(",");
myFile.print(",");
myFile.print(",");
myFile.print(",");
myFile.print(",");
myFile.print(",");
myFile.print(",");
myFile.close();
void stampRS3(){
myFile.print(",");
myFile.print(",");
myFile.print(",");
myFile.print(",");
myFile.print(",");
myFile.print(",");
myFile.print(",");
myFile.close();
void stampRS4(){
myFile.print(",");
myFile.print(",");
myFile.print(",");
myFile.print(",");
myFile.print(",");
myFile.print(",");
myFile.print(",");
myFile.close();
void stampchk(){
myFile.print(",");
myFile.print("Rchk");
myFile.print(",");
myFile.print("RChk");
myFile.print(",");
myFile.print(",");
myFile.print(",");
myFile.print(",");
myFile.print(",");
// ใส่ค่า LDR myFile.print(" ");
myFile.print(",");
myFile.println("Schk");
myFile.close();
delay(10000);
///สั่งปิดรีเลด้วย
myFile.print(",");
myFile.print(",");
myFile.print(",");
myFile.print(",");
myFile.print(",");
myFile.print(",");
myFile.print("humidity");
myFile.print(",");
myFile.print(",");
myFile.println("Echk");
myFile.close();
void translateIR() // takes action based on IR code received
// describing Remote IR codes
switch(results.value)
case 0xFFA25D: Serial.println(" CH-"); break;
case 0xFF629D: Serial.println(" CH"); break;
case 0xFFE21D: Serial.println(" CH+"); break;
case 0xFF22DD: Serial.println(" PREV"); break;
case 0xFF02FD: Serial.println(" NEXT"); break;
case 0xFFC23D: Serial.println(" PLAY/PAUSE"); break;
case 0xFFE01F: Serial.println(" VOL-"); break;
case 0xFFA857: Serial.println(" VOL+"); break;
case 0xFF906F: Serial.println(" EQ"); break;
case 0xFF6897: Serial.println(" 0"); break;
case 0xFF9867: Serial.println(" 100+"); break;
case 0xFFB04F: Serial.println(" 200+"); break;
case 0xFF30CF: Serial.println(" 1"); break;
case 0xFF18E7: Serial.println(" 2"); break;
case 0xFF7A85: Serial.println(" 3"); break;
case 0xFF10EF: Serial.println(" 4"); break;
case 0xFF38C7: Serial.println(" 5"); break;
case 0xFF5AA5: Serial.println(" 6");break;
case 0xFF42BD: Serial.println(" 7");break;
case 0xFF4AB5: Serial.println(" 8");break;
case 0xFF52AD: Serial.println(" 9");break;
case 0xFF94C0DF89: Serial.println(" Recive"); stampRS1(); break;
//default:
// Serial.println(" other button ");
}// End Case
delay(500); // Do not get immediate repeat
} //END translateIR
//-----------------------นาฬิกา-----------------
//----ถ้า alrm triggered ให้ทำอะไร--------
void alarm(){
if (clock.isAlarm1())
Serial.println(F("ALARM 1 TRIGGERED!"));
if (clock.isAlarm2())
Serial.println(F("ALARM 2 TRIGGERED!"));
timestamp();
void checkAlarms()
RTCAlarmTime a1;
RTCAlarmTime a2;
if (clock.isArmed1())
a1 = clock.getAlarm1();
Serial.print(F("Alarm1 is triggered "));
switch (clock.getAlarmType1())
case DS3231_EVERY_SECOND:
Serial.println(F("every second"));
break;
case DS3231_MATCH_S:
Serial.print(F("when seconds match: "));
Serial.println(clock.dateFormat("__ __:__:s", a1));
break;
case DS3231_MATCH_M_S:
Serial.print(F("when minutes and sencods match: "));
Serial.println(clock.dateFormat("__ __:i:s", a1));
break;
case DS3231_MATCH_H_M_S:
Serial.print(F("when hours, minutes and seconds match: "));
Serial.println(clock.dateFormat("__ H:i:s", a1));
break;
case DS3231_MATCH_DT_H_M_S:
Serial.print(F("when date, hours, minutes and seconds match: "));
Serial.println(clock.dateFormat("d H:i:s", a1));
break;
case DS3231_MATCH_DY_H_M_S:
Serial.print(F("when day of week, hours, minutes and seconds match: "));
Serial.println(clock.dateFormat("l H:i:s", a1));
break;
default:
Serial.println(F("UNKNOWN RULE"));
break;
} else
Serial.println(F("Alarm1 is disarmed."));
if (clock.isArmed2())
a2 = clock.getAlarm2();
Serial.print(F("Alarm2 is triggered "));
switch (clock.getAlarmType2())
case DS3231_EVERY_MINUTE:
Serial.println(F("every minute"));
break;
case DS3231_MATCH_M:
Serial.print(F("when minutes match: "));
Serial.println(clock.dateFormat("__ __:i:s", a2));
break;
case DS3231_MATCH_H_M:
Serial.print(F("when hours and minutes match:"));
Serial.println(clock.dateFormat("__ H:i:s", a2));
break;
case DS3231_MATCH_DT_H_M:
Serial.print(F("when date, hours and minutes match: "));
Serial.println(clock.dateFormat("d H:i:s", a2));
break;
case DS3231_MATCH_DY_H_M:
Serial.println(F("when day of week, hours and minutes match: "));
Serial.print(clock.dateFormat("l H:i:s", a2));
break;
default:
break;
} else
Serial.println(F("Alarm2 is disarmed."));
//--------------------------------save log blynk--------------------
void logv1on(){
myFile.print(",");
myFile.print("Blynk on");
myFile.print(",");
myFile.print(",");
myFile.print(",");
myFile.print(",");
myFile.print(",");
myFile.print(",");
myFile.close();
void logv1off(){
myFile.print(",");
myFile.print("Blynk off");
myFile.print(",");
myFile.print(",");
myFile.print(",");
myFile.print(",");
myFile.print(",");
myFile.print(",");
myFile.close();
//--------------------end v1 -----------------------------
void logv2on(){
myFile.print(",");
myFile.print(",");
myFile.print(",");
myFile.print(",");
myFile.print(",");
myFile.print(",");
myFile.print(",");
myFile.close();
void logv2off(){
myFile.print(",");
myFile.print(",");
myFile.print(",");
myFile.print(",");
myFile.print(",");
myFile.print(",");
myFile.print(",");
myFile.close();
//--------------------end v2 -----------------------------
void logv3on(){
myFile.print(",");
myFile.print(",");
myFile.print(",");
myFile.print(",");
myFile.print(",");
myFile.print(",");
myFile.print(",");
myFile.close();
void logv3off(){
myFile.print(",");
myFile.print(",");
myFile.print(",");
myFile.print(",");
myFile.print(",");
myFile.print(",");
myFile.print(",");
myFile.close();
//--------------------end v3 -----------------------------
void logv4on(){
myFile.print(",");
myFile.print(",");
myFile.print(",");
myFile.print(",");
myFile.print(",");
myFile.print(",");
myFile.print(",");
myFile.close();
void logv4off(){
myFile.print(",");
myFile.print(",");
myFile.print(",");
myFile.print(",");
myFile.print(",");
myFile.print(",");
myFile.print(",");
myFile.close();
//--------------------end v4 -----------------------------
void logv5on(){
myFile.print(",");
myFile.print(",");
myFile.print(",");
myFile.print(",");
myFile.print(",");
myFile.print(",");
myFile.print(",");
myFile.close();
void logv5off(){
myFile.print(",");
myFile.print(",");
myFile.print(",");
myFile.print(",");
myFile.print(",");
myFile.print(",");
myFile.print(",");
myFile.close();
//--------------------end v5 -----------------------------
