Connect to local blynk server via bluetooth
after much searching, I cant find (a) if this is possible (b) how.
I have a mobile wifi network , a RaspPi blynk server, and 10 arduinos, wemos and NodeMCUs, all connect and work as expected on the wifi. My android phone Blynk app connects and works as expected when connected to the wifi also.
BUT It would be far preferable to connect directly to the raspberry pi blynk server via bluetooth. Has anyone done this?
to reiterate, all microprocessors and server are on the same wifi, but id like the phone app to connect to the server via bluetooth.
any points in the correct direction would be great.
thanks in advance for any info.
blake
I’m not quite sure about what you’re trying to do here… The Blynk server (and client) only works networked (TCP/IP). So my answer is a) No and b) N/a. :confused:
