Make sure your’re using the latest lib: “1.0.0”
Then, try this in boot.py (I’m using a modified wifimanager to collect Blynk’s credentials but you can omit it and use a standard wlan connection:
from umachine import RTC, Pin, reset
import ntptime
import utime
from usys import platform, implementation
import gc
import wifimgr
gc.collect()
ESP32 = platform == 'esp32' or platform == 'esp32_LoBo'
RP2 = platform == 'rp2'
ESP8266 = platform == 'esp8266'
if ESP8266 or ESP32:
def ledfunc(pin):
pin = pin
def func(v):
pin(not v) # Active low on ESP8266
return func
led = ledfunc(Pin(16, Pin.OUT, value = 0)) # LED for WiFi fail/not ready yet
if RP2:
def ledfunc(pin):
pin = pin
def func(v):
pin(v)
return func
wifi_led = lambda _ : None # Only one LED
LED = 'LED' if 'Pico W' in implementation._machine else 25
green_led = ledfunc(Pin(LED, Pin.OUT, value = 1)) # Message received
def flash_led():
for x in range(5):
green_led(False)
utime.sleep(.25)
green_led(True)
utime.sleep(.5)
flash_led()
def restart_and_reconnect(reason):
print('Some went wrong. Reconnecting...')
print('Due to ', reason)
utime.sleep(5)
reset()
try:
wlan = wifimgr.get_connection()
# wlan.disconnect()
if wlan is None:
print("Could not initialize the network connection.")
while True:
pass # you shall not pass :D
except Exception:
print('Connection error')
reset()
ssid = wifimgr.get_profiles()[0]
BLYNK_AUTH = wifimgr.get_profiles()[2]
# print("Network config:", wlan.ifconfig())
# sync time
utime.sleep(1)
try:
rtc = RTC()
ntptime.settime() # set the rtc datetime from the remote server
rtc.datetime() # get the date and time in UTC
except Exception as e:
print(e)
def cetTime():
year = utime.localtime()[0] #get current year
HHMarch = utime.mktime((year,3 ,(31-(int(5*year/4+4))%7),1,0,0,0,0,0)) #Time of March change to CEST
HHOctober = utime.mktime((year,10,(31-(int(5*year/4+1))%7),1,0,0,0,0,0)) #Time of October change to CET
now=utime.time()
if now < HHMarch : # we are before last sunday of march
cet=utime.localtime(now+3600) # CET: UTC+1H
elif now < HHOctober : # we are before last sunday of october
cet=utime.localtime(now+7200) # CEST: UTC+2H
else: # we are after last sunday of october
return(cet)
print(str(cetTime()[3]) + ':' + str(cetTime()[4]))
green_led(False)
gc.collect()
At boot, the above will display CET time (Madrid in my case). No need to use main.py to test the above code.
In main.py use:
import BlynkLib
from BlynkTimer import BlynkTimer
DEBUG = True
def dprint(*args):
if DEBUG:
print(*args)
dprint('Memory free', gc.mem_free())
VERSION = "1.0"
dprint('Code version: ', VERSION)
timer = BlynkTimer()
BLYNK_GREEN = "#23C48E"
BLYNK_BLUE = "#04C0F8"
BLYNK_YELLOW = "#ED9D00"
BLYNK_RED = "#D3435C"
BLYNK_DARK_BLUE = "#5F7CD8"
def R1_timeout(): green_led(False)
# Initialize Blynk
try:
# blynk = BlynkLib.Blynk(BLYNK_AUTH) # faster
# or....
blynk = BlynkLib.Blynk(BLYNK_AUTH,
insecure=True, # disable SSL/TLS
server='lon1.blynk.cloud', # lon1 fra1.blynk.cloud or blynk.cloud
port=80, # set server port
heartbeat=30, # set heartbeat to 30 secs
log=dprint # use print function for debug logging
except OSError as e:
dprint('ERROR', e)
restart_and_reconnect(e)
@blynk.on("connected")
def blynk_connected(ping):
dprint('Blynk ready. Ping:', ping, 'ms')
blynk.sync_virtual()
@blynk.on("disconnected")
def blynk_disconnected():
dprint('Blynk disconnected')
utime.sleep(5)
restart_and_reconnect('Blynk server failure...')
def check_wifi():
gaugeColor = ''
s = network.WLAN()
e_ssid = ssid.encode('UTF8')
try:
rssi = [x[3] for x in s.scan() if x[0] == e_ssid][0]
if (rssi > -99 and rssi < -80):
newColor = BLYNK_RED
elif (rssi <= -80 and rssi < -60):
newColor = BLYNK_YELLOW
else: newColor = BLYNK_GREEN
if (newColor != gaugeColor):
gaugeColor = newColor
blynk.set_property(10, "color", gaugeColor)
blynk.virtual_write(10, rssi)
except IndexError as e: # ssid not found.
dprint('IndexError', e)
rssi = -99
def uptime():
blynk.virtual_write(0, utime.time()/10000)
@blynk.on("V1")
def blynk_handle(value):
if int(value[0]) == 1:
green_led(True)
timer.set_timeout(1, R1_timeout)
else: pass
def Loop():
while True:
gc.collect()
blynk.run()
timer.run()
# check on wifi every 15 seconds
timer.set_interval(15, check_wifi)
timer.set_interval(1, uptime)
# Run blynk in the main thread
try:
# import _thread
Loop()
# _thread.stack_size(5*1024)
# _thread.start_new_thread(Loop, ())
print(e)
You may need to change your Blynk local server. Mine is set to “lon1”. Pressing the V1 button on your app, the pico w’s LED should turn on/off. Beside that, you have a dbm gauge and an uptime display on your app. Just follow the code.
