I currently work with an automation system for agricultural irrigation, but I use more than 20 devices all performing the same function, however I need a code for each device just with a different authentication token. Is there any method for me to load the same firmware containing all the tokens and make them all work?
You might be better looking at Blynk Edgent, as it allows auth tokens to be provisioned dynamically.
There is very good doc about it here - Deploying Products With Dynamic AuthTokens | Blynk Documentation
