Dear all,
I’m having a problem that may be simple, but I’m not making any progress. I connected an ADS1115 module to an ESP8266 without any problems, so I could use it with some analog sensors. It worked perfectly. Now I want to connect this to an ESP32 that comes in a kit with a LoRa and an OLED. It’s an ESP32-S3FN8 development board. I simply want to connect it to the ADS1115, but it’s not working. I don’t know where I’m going wrong. I’m sending you the pinout and an image of the ESP32 for guidance. Thank you.
TEST CODE
#include <Wire.h>
#include <Adafruit_ADS1X15.h>
const int SDA_PIN = 21; // GPIO21
const int SCL_PIN = 18; // GPIO18
Adafruit_ADS1115 ads; // Ganancia por defecto +/-6.144V
Wire.begin(SDA_PIN, SCL_PIN);
if (!ads.begin(0x48)) {
Serial.println("No se encontró ADS1115 en 0x48. Revisá cables/alimentación.");
while (1) delay(10);
// Opcional: para señales de 0–3.3V, esta ganancia anda bien
ads.setGain(GAIN_ONE); // ±4.096 V (1 bit ≈ 0.125 mV)
Serial.println("ADS1115 OK. Leyendo A0 en single-ended...");
int16_t raw = ads.readADC_SingleEnded(0); // Canal A0 del ADS1115
float volts = raw * 0.125f / 1000.0f; // 0.125 mV por bit con GAIN_ONE
Serial.printf("A0: raw=%d V=%.4f\n", raw, volts);
delay(500);
SERIAL:
19:03:50.656 → ESP-ROM:esp32s3-20210327 19:03:50.656 → Build:Mar 27 2021 19:03:50.656 → rst:0x1 (POWERON),boot:0x8 (SPI_FAST_FLASH_BOOT) 19:03:50.656 → SPIWP:0xee 19:03:50.656 → mode:DIO, clock div:1 19:03:50.656 → load:0x3fce2820,len:0x1180 19:03:50.697 → load:0x403c8700,len:0xc2c 19:03:50.697 → load:0x403cb700,len:0x311c 19:03:50.697 → entry 0x403c88b8 19:03:50.978 → Escaneando I2C… 19:03:51.025 → E (264) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:51.025 → E (269) i2c.master: I2C hardware timeout detected 19:03:51.025 → E (269) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:51.073 → E (332) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:51.120 → E (387) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:51.212 → E (442) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:51.258 → E (497) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:51.305 → E (552) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:51.351 → E (607) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:51.397 → E (662) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:51.490 → E (717) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:51.537 → E (772) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:51.582 → E (827) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:51.629 → E (882) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:51.675 → E (937) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:51.769 → E (992) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:51.816 → E (1047) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:51.862 → E (1102) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:51.909 → E (1157) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:51.955 → E (1212) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:52.001 → E (1267) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:52.095 → E (1322) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:52.147 → E (1377) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:52.188 → E (1432) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:52.235 → E (1487) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:52.281 → E (1542) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:52.375 → E (1597) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:52.421 → E (1652) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:52.466 → E (1707) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:52.512 → E (1762) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:52.558 → E (1817) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:52.650 → E (1872) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:52.700 → E (1927) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:52.746 → E (1982) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:52.789 → E (2037) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:52.835 → E (2092) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:52.881 → E (2147) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:52.973 → E (2202) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:53.019 → E (2257) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:53.065 → E (2312) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:53.113 → E (2367) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:53.158 → E (2422) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:53.251 → E (2477) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:53.298 → E (2532) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:53.345 → E (2587) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:53.390 → E (2642) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:53.436 → E (2697) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:53.527 → E (2752) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:53.573 → E (2807) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:53.620 → E (2862) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:53.666 → E (2917) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:53.713 → E (2972) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:53.804 → E (3027) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:53.850 → E (3082) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:53.897 → E (3137) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:53.943 → E (3192) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:53.995 → E (3247) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:54.037 → E (3302) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:54.130 → E (3357) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:54.177 → E (3412) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:54.223 → E (3467) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:54.270 → E (3522) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:54.315 → E (3577) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:54.407 → E (3632) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:54.454 → E (3687) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:54.499 → E (3742) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:54.546 → E (3797) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:54.591 → E (3852) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:54.683 → E (3907) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:54.731 → E (3962) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:54.778 → E (4017) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:54.824 → E (4072) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:54.871 → E (4127) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:54.917 → E (4182) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:55.008 → E (4237) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:55.055 → E (4292) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:55.102 → E (4347) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:55.148 → E (4402) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:55.194 → E (4457) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:55.286 → E (4512) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:55.332 → E (4567) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:55.379 → E (4622) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:55.425 → E (4677) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:55.472 → E (4732) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:55.564 → E (4787) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:55.612 → E (4842) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:55.657 → E (4897) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:55.703 → E (4952) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:55.750 → E (5007) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:55.797 → E (5062) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:55.890 → E (5117) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:55.936 → E (5172) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:55.982 → E (5227) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:56.027 → E (5282) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:56.074 → E (5337) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:56.172 → E (5392) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:56.213 → E (5447) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:56.260 → E (5502) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:56.306 → E (5557) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:56.353 → E (5612) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:56.447 → E (5667) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:56.493 → E (5722) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:56.541 → E (5777) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:56.586 → E (5832) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:56.634 → E (5887) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:56.682 → E (5942) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:56.772 → E (5997) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:56.818 → E (6052) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:56.864 → E (6107) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:56.911 → E (6162) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:56.957 → E (6217) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:57.050 → E (6272) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:57.096 → E (6327) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:57.142 → E (6382) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:57.189 → E (6437) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:57.235 → E (6492) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:57.283 → E (6547) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:57.375 → E (6602) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:57.421 → E (6657) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:57.466 → E (6712) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:57.512 → E (6767) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:57.559 → E (6822) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:57.650 → E (6877) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:57.697 → E (6932) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:57.743 → E (6987) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:57.793 → E (7042) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:57.836 → E (7097) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up 19:03:57.883 → No se encontró nada ![]()
