Connect Econnrefused Rpi Part2
Excuse sir, at this link
I use Raspberry Pi 3 and still have error,
Firewall my raspi has disabled.
So, can teach me. How to fix it
Thx for helping
Connecting to: blynk-cloud.com 8441
{ Error: connect ECONNREFUSED 188. 166.206.43:8441
at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1117:14)
code: ‘ECONNREFUSED’,
errno: ‘ECONNREFUSED’,
syscall: ‘connect’,
address: ‘188.166.206.43’,
port: 8441 }
Did it work at one time, or has it always been broken? Can you post your top most code for use to view?
I use blynk first time, when I follow instruction on any website. After
blynk-client BLYNK_AUTH
It always been broken.
So can help me for this problem…
there is a mistake in the instructions … it says "npm install npm… you want to do an “apt-get install npm”…
but, assuming you caught it during the install…
copy and paste what happens when you do a “blynk-client <authcode>”
anykind of upstream firewall in place, i know you said the pi firewall was turned off ?
can you install nslookup?
apt-get install dnsutils
and run it on blynk-cloud.com?
root@raspberrypi:~# nslookup blynk-cloud.com
Server:         75.75.75.75
Address:        75.75.75.75#53
Non-authoritative answer:
Address: 45.55.96.146
i have same problem
I didn’t change anything on my RPi, but when i start my script now, I get that message:
{ Error: connect ECONNREFUSED 139.59.206.133:8441
    at Object._errnoException (util.js:1022:11)
    at _exceptionWithHostPort (util.js:1044:20)
    at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1198:14)
  code: 'ECONNREFUSED',
  errno: 'ECONNREFUSED',
  syscall: 'connect',
  address: '139.59.206.133',
  port: 8441 }
I have no idea what the problem is.
Thanks for helping.
The new (as of last year) proper port for SSL is 9443. Recent server issues now insist upon it.
You need to confirm updated library and/or edit a line in it for the new proper port.
See this topic for details…
