Hi all,
Having fairly major problems with staying connected to my local blynk server, my project is using a GSM connection. I was having no trouble at all when I had only 1-2 sensors and read/write virtual pins enabled but now ive added a third sensor and relavent code (with the ambition to add a forth in the near future) I’m getting it successfully connecting to my local server and a second later it disconnects. It goes on like this for a minute then hangs.
One thing I’ve noticed is even with 1-2 sensors running, if I was to tap a button or move a slider on the app too close to another command it would also cause a disconnect to the server.
My guess is it is something to do with my timers. I’m not sure how I can improve this any more? I have it running sections of code for a second with interupts between the timers to stagger them. Can anyone solve my connection problem?
Code below:
// Hardware definitions
#define TINY_GSM_MODEM_SIM800
// First we include the libraries
#include <TinyGsmClient.h>
#include <BlynkSimpleSIM800.h>
#include <OneWire.h>
#include <INA226.h>
// Hardware input to board
#define ONE_WIRE_BUS 4 // Temperature sensor on digital pin 4
#define TURB_READ A0 // Turbidity sensor on analog pin 0
#define PH_READ A1 // pH sensor on analog pin 1
// Setup a oneWire instance to communicate with any OneWire devices
// (not just Maxim/Dallas temperature ICs)
// Pass our oneWire reference to Dallas Temperature.
int sendTimer1, sendTimer2, sendTimer3, sendTimer4, sendTimer5;
// Alert messages
char alertTemp_MessageLow[] = "Temperature is LOW!";
char alertTemp_MessageHigh[] = "Temperature is HIGH!";
char alertTurb_MessageHigh[] = "Turbidity is HIGH!";
char alertTurb_MessageHighHigh[] = "Turbidity is HIGH HIGH!";
char alertpH_MessageLow[] = "pH is LOW!";
char alertpH_MessageHigh[] = "pH is HIGH!";
float alertTempLow; // Temperature at/below which alerts will be sent
float alertTempHigh; // Temperature above which alerts will be sent
float alertTurbHigh; // Turbidity at/above which alerts will be sent
float alertTurbHighHigh; // Turbidity above which alerts will be sent
float alertpHLow; // Temperature at/below which alerts will be sent
float alertpHHigh; // Temperature above which alerts will be sent
boolean lowAlertOn_Temp = false; // flag to show that low alert message has been sent via Blynk
boolean highAlertOn_Temp = false; // flag to show that highalert message has been sent via Blynk
boolean highAlertOn_Turb = false; // flag to show that low alert message has been sent via Blynk
boolean highhighAlertOn_Turb = false; // flag to show that highalert message has been sent via Blynk
boolean lowAlertOn_pH = false; // flag to show that low alert message has been sent via Blynk
boolean highAlertOn_pH = false; // flag to show that highalert message has been sent via Blynk
// Minimum and maximum temperatures are set to out of range values that will be
// overridden the first time the actual values are read.
float minTemp = 10000.0;
float maxTemp = -10000.0;
float minTurb = 10000.0;
float maxTurb = -10000.0;
float minpH = 10000.0;
float maxpH = -10000.0;
float currentTemp; // Current temperature reading
float currentTurb; // Current turbidity reading
float currentpH; // Current pH reading
// pH Buffer and Calibration factors
float calibrationpH = 21.40;
int sensorValue = 0;
unsigned long int avgValue;
float b;
int buf[10],temp;
#define ALERT_HYSTERESIS 1 // Hysteresis for alerts
// Widget colors for alerts
#define ALERT_COLOR_OK "#23C48E" // Green
#define ALERT_COLOR_LOW "#5F7CD8" // Dark Blue
#define ALERT_COLOR_HIGH "#D3435C" // Red
//GPRS credentials
char apn[] = "internet"; // General apn being used for GPRS to connect to public internet
char user[] = "";
char pass[] = "";
char auth[] = ""; // Local server project authorisation code
char server[] = "xxx.onmypc.net"; // DDNS server pointed to home WAN IP
int port = 8080; // Port being forwarded via home router to Raspberry Pi
SoftwareSerial SerialAT(2, 3); // RX, TX
TinyGsm modem(SerialAT);
Serial.begin(19200); // Start debugging if needed
sensors.begin(); // Calls for Temperature sensor to start from library
// Set GSM module baud rate
SerialAT.begin(19200);
delay(3000);
modem.restart();
Blynk.begin(auth, modem, apn, user, pass, server, port); // Local server credentials and server connection details called
// Setup the functions every second
timer.setTimeout(200, []() {
sendTimer1 = timer.setInterval(1000, TempSensorRead);
timer.setTimeout(400, []() {
sendTimer2 = timer.setInterval(1000, TurbiditySensorRead);
timer.setTimeout(600, []() {
sendTimer3 = timer.setInterval(1000, pHSensorRead);
//timer.setTimeout(800, []() {
//sendTimer4 = timer.setInterval(1000, ChlorineSensorRead);
// Temperature sensor begin
void TempSensorRead(){
currentTemp = sensors.getTempCByIndex(0);
Blynk.virtualWrite(V0, currentTemp);
// Low temperature alerts
if ((currentTemp <= alertTempLow) && !lowAlertOn_Temp) {
Blynk.setProperty(V0, "color", ALERT_COLOR_LOW);
Blynk.notify(alertTemp_MessageLow);
lowAlertOn_Temp = true;
else if (lowAlertOn_Temp && (currentTemp > alertTempLow + ALERT_HYSTERESIS)) {
Blynk.setProperty(V0, "color", ALERT_COLOR_OK);
// High temperature alerts
if ((currentTemp >= alertTempHigh) && !highAlertOn_Temp) {
Blynk.setProperty(V0, "color", ALERT_COLOR_HIGH);
Blynk.notify(alertTemp_MessageHigh);
highAlertOn_Temp = true;
else if (highAlertOn_Temp && (currentTemp < alertTempHigh - ALERT_HYSTERESIS)) {
if (currentTemp < minTemp) {
minTemp = currentTemp;
Blynk.virtualWrite(V5, currentTemp);
if (currentTemp > maxTemp) {
maxTemp = currentTemp;
Blynk.virtualWrite(V6, currentTemp);
// Set low alert temperature
BLYNK_WRITE(V1) {
alertTempLow = param.asFloat();
Blynk.virtualWrite(V2, alertTempLow);
// Set high alert temperature
BLYNK_WRITE(V3) {
alertTempHigh = param.asFloat();
Blynk.virtualWrite(V4, alertTempHigh);
// Reset minimum and maximum temperatures
BLYNK_WRITE(V7) {
minTemp = maxTemp = currentTemp;
// Temperature sensor end
// Turbidity sensor begin
float fmapTurb(float x, float in_min, float in_max, float out_min, float out_max) // Scaling routine
return (x - in_min) * (out_max - out_min) / (in_max - in_min) + out_min;
void TurbiditySensorRead(){
//int RawTurbValue = analogRead(TURB_READ); // This line and the following allow for raw sensor data gathering for calibration
//Blynk.virtualWrite(V8, RawTurbValue);
int RawTurbValue = analogRead(TURB_READ); // Analog data is read from A0
float currentTurb = fmapTurb(RawTurbValue, 0, 685, 5.0, 0.0); // Mapping routine for scaling raw data to engineering units
Blynk.virtualWrite(V8, currentTurb);
// High turbidity alerts
if ((currentTurb <= alertTurbHigh) && !highAlertOn_Turb) {
Blynk.setProperty(V8, "color", ALERT_COLOR_HIGH);
Blynk.notify(alertTurb_MessageHigh);
highAlertOn_Turb = true;
else if (highAlertOn_Turb && (currentTurb > alertTurbHigh + ALERT_HYSTERESIS)) {
Blynk.setProperty(V8, "color", ALERT_COLOR_OK);
// High High turbidity alerts
if ((currentTurb >= alertTurbHighHigh) && !highhighAlertOn_Turb) {
Blynk.notify(alertTurb_MessageHighHigh);
highhighAlertOn_Turb = true;
else if (highhighAlertOn_Turb && (currentTurb < alertTurbHighHigh - ALERT_HYSTERESIS)) {
// Minimum and maximum turbidity
if (currentTurb < minTurb) {
minTurb = currentTurb;
Blynk.virtualWrite(V13, currentTurb);
if (currentTurb > maxTurb) {
maxTurb = currentTurb;
Blynk.virtualWrite(V14, currentTurb);
// Set low alert turbidity
BLYNK_WRITE(V9) {
alertTurbHigh = param.asFloat();
Blynk.virtualWrite(V10, alertTurbHigh);
// Set high alert turbidity
BLYNK_WRITE(V11) {
alertTurbHighHigh = param.asFloat();
Blynk.virtualWrite(V12, alertTurbHighHigh);
// Reset minimum and maximum turbidity
BLYNK_WRITE(V15) {
minTurb = maxTurb = currentTurb;
// Turbidity sensor end
// pH sensor begin
void pHSensorRead(){
for(int i=0;i<10;i++)
buf[i]=analogRead(A1);
delay(30);
for(int i=0;i<9;i++)
for(int j=i+1;j<10;j++)
if(buf[i]>buf[j])
temp=buf[i];
buf[i]=buf[j];
buf[j]=temp;
avgValue=0;
for(int i=2;i<8;i++)
avgValue+=buf[i];
float pHVol=(float)avgValue*5.0/1024/6;
float currentpH = -5.70 * pHVol + calibrationpH;
Blynk.virtualWrite(V16, currentpH);
// Low pH alerts
if ((currentpH <= alertpHLow) && !lowAlertOn_pH) {
Blynk.setProperty(V16, "color", ALERT_COLOR_LOW);
Blynk.notify(alertpH_MessageLow);
lowAlertOn_pH = true;
else if (lowAlertOn_pH && (currentpH > alertpHLow + ALERT_HYSTERESIS)) {
Blynk.setProperty(V16, "color", ALERT_COLOR_OK);
// High pH alerts
if ((currentpH >= alertpHHigh) && !highAlertOn_pH) {
Blynk.setProperty(V16, "color", ALERT_COLOR_HIGH);
Blynk.notify(alertpH_MessageHigh);
highAlertOn_pH = true;
else if (highAlertOn_pH && (currentpH < alertpHHigh - ALERT_HYSTERESIS)) {
// Minimum and maximum pH
if (currentpH < minpH) {
minpH = currentpH;
Blynk.virtualWrite(V21, currentpH);
if (currentpH > maxpH) {
maxpH = currentpH;
Blynk.virtualWrite(V22, currentpH);
// Set low alert pH
BLYNK_WRITE(V17) {
alertpHLow = param.asFloat();
Blynk.virtualWrite(V18, alertpHLow);
// Set high alert pH
BLYNK_WRITE(V19) {
alertpHHigh = param.asFloat();
Blynk.virtualWrite(V20, alertpHHigh);
BLYNK_WRITE(V23) {
minpH = maxpH = currentpH;
// pH sensor end
