Hello Pete,
One BME280 and one DS3231 paralell on A4,A5 pins.
Analogread on A0,A1,A2 (water level check)
7 digital output to Pump and valves…
One hall sensor on D2 (Int0) for flowcheck.
My code could be “simple or ugly” and not so professional.
I’m not a “programmer” I learning from tutorials, and from google
SoftwareSerial mySerial(11, 12);
#define BLYNK_PRINT mySerial
#define BLYNK_DEBUG
#include <Wire.h>
#include <BME280I2C.h>
#include <ESP8266_Lib.h>
#include "RTClib.h"
#include <EEPROM.h>
RTC_DS3231 rtc;
unsigned long tempMillis;
byte sensorInterrupt = 0; // 0 = digital pin 2
float calibrationFactor = 4.5;
byte sensorPin = 2;
volatile byte pulseCount;
float flowRate;
unsigned int flowMilliLitres;
unsigned long totalMilliLitres;
unsigned long oldTime;
int spHead[] = {0, 3, 4, 5, 6, 7, 8, 9};
int weekDays[] = {0, 0, 0, 0, 0, 0, 0, 0};
int Sp[] = {0, 0, 0, 0, 0, 0, 0, 0};
int spEn = 1;
int spStart = 0;
int spNum = 1;
int pumpEn = 0;
int pumpOverLock = 0;
char auth[] = "CfPzmcC0ivud-szaWy0OY7U2hox17NQD";
char ssid[] = "xxxxx";
char pass[] = "xxxxx";
#define ESP8266_BAUD 9600
ESP8266 wifi(&Serial);
WidgetLED led1(V3);
WidgetLED led2(V4);
WidgetLED led3(V5);
//WidgetLCD lcd(V31);
int prog1Hour;
int prog1Minute;
BLYNK_WRITE(V15) {
TimeInputParam t(param);
prog1Hour = t.getStartHour();
prog1Minute = t.getStartMinute();
for (int i = 1; i <= 7; i++) {
weekDays[i] = 0;
if (t.isWeekdaySelected(i)) {
weekDays[i] = 1;
BME280I2C::Settings settings(
BME280::OSR_X1,
BME280::OSR_X1,
BME280::OSR_X1,
BME280::Mode_Forced,
BME280::StandbyTime_1000ms,
BME280::Filter_Off,
BME280::SpiEnable_False,
0x76 // I2C address. I2C specific.
BME280I2C bme(settings);
////////////////////////////////////////////////////////////////////SETUP
mySerial.begin(9600);
if (! rtc.begin()) {
Serial.println("Couldn't find RTC");
while (1);
rtc.adjust(DateTime(F(__DATE__), F(__TIME__)));
pinMode(sensorPin, INPUT);
digitalWrite(sensorPin, HIGH);
pulseCount = 0;
flowRate = 0.0;
flowMilliLitres = 0;
totalMilliLitres = 0;
oldTime = 0;
attachInterrupt(sensorInterrupt, pulseCounter, FALLING);
for (int x = 3; x != 10; x++) {
pinMode(x, OUTPUT);
digitalWrite(x, LOW);
pinMode(10, OUTPUT);
digitalWrite(10, HIGH);
while (!Serial) {}
Wire.begin();
while (!bme.begin())
// Change some settings before using.
settings.tempOSR = BME280::OSR_X4;
bme.setSettings(settings);
for (int x = 1; x <= 7; x++) {
Sp[x] = EEPROM.read(x);
weekDays[x] = EEPROM.read(x + 7);
prog1Hour = EEPROM.read(15);
prog1Minute = EEPROM.read(16);
Blynk.begin(auth, wifi, ssid, pass, "192.168.1.99", 8080);
//delay(200);
timer.setInterval(60000L, sendBME280);
timer.setInterval(10000L, levelCheck);
timer.setInterval(20000L, startSignal);
timer.setInterval(1000L, spinklerCheck);
// timer.setInterval(8000L, flowRateCheck);
/////////////////////////////////////////////////////////////////////////////////////////////////////////LOOP
//////////////////////////////////////////////////////////////////////////////////////////////////Blynk
BLYNK_WRITE(V6) {
int sp1 = param.asInt();
if (sp1 == 1 ) {
digitalWrite(3, HIGH);
else {
digitalWrite(3, LOW);
BLYNK_WRITE(V7) {
int sp2 = param.asInt();
if (sp2 == 1 ) {
digitalWrite(4, HIGH);
else {
digitalWrite(4, LOW);
BLYNK_WRITE(V8) {
int sp3 = param.asInt();
if (sp3 == 1 ) {
digitalWrite(5, HIGH);
else {
digitalWrite(5, LOW);
BLYNK_WRITE(V9) {
int sp4 = param.asInt();
if (sp4 == 1 ) {
digitalWrite(6, HIGH);
else {
digitalWrite(6, LOW);
BLYNK_WRITE(V10) {
int sp5 = param.asInt();
if (sp5 == 1 ) {
digitalWrite(7, HIGH);
else {
digitalWrite(7, LOW);
BLYNK_WRITE(V11) {
int sp6 = param.asInt();
if (sp6 == 1 ) {
digitalWrite(8, HIGH);
else {
digitalWrite(8, LOW);
BLYNK_WRITE(V12) {
int sp7 = param.asInt();
if (sp7 == 1 ) {
digitalWrite(9, HIGH);
else {
digitalWrite(9, LOW);
BLYNK_WRITE(V13) {
int sziv = param.asInt();
if (sziv == 1 ) {
digitalWrite(10, LOW);
else {
BLYNK_WRITE(V18) {
if (sziv == 1 ) {
else {
BLYNK_WRITE(V20) {
Sp[1] = param.asInt() * 10;
EEPROM.write(1, Sp[1]);
BLYNK_WRITE(V21) {
Sp[2] = param.asInt() * 10;
EEPROM.write(2, Sp[2]);
BLYNK_WRITE(V22) {
Sp[3] = param.asInt() * 10;
EEPROM.write(3, Sp[3]);
BLYNK_WRITE(V23) {
Sp[4] = param.asInt() * 10;
EEPROM.write(4, Sp[4]);
BLYNK_WRITE(V24) {
Sp[5] = param.asInt() * 10;
EEPROM.write(5, Sp[5]);
BLYNK_WRITE(V25) {
Sp[6] = param.asInt() * 10;
EEPROM.write(6, Sp[6]);
BLYNK_WRITE(V26) {
Sp[7] = param.asInt() * 10;
EEPROM.write(7, Sp[7]);
BLYNK_WRITE(V27) {
spEn = param.asInt();
BLYNK_WRITE(V28) {
int eprom = param.asInt();
for (int x = 7; x <= 14; x++) {
EEPROM.write(x, weekDays[x]);
EEPROM.write(15, prog1Hour);
EEPROM.write(16, prog1Minute);
BLYNK_WRITE(V30) {
pumpOverLock = param.asInt();
////////////////////////////////////////////////////////////////////////////////////////////////////////VOID
void sendBME280() {
// Serial.println (humidity);
float temp(NAN), hum(NAN), pres(NAN);
bme.read(pres, temp, hum);
pres /= 100;
Blynk.virtualWrite(V0, temp );
Blynk.virtualWrite(V1, hum);
Blynk.virtualWrite(V2, pres);
void levelCheck() {
if (pumpEn == 1 && pumpOverLock == 0) {
flowRateCheck();
if (analogRead(0) > 600) {
led1.on();
else {
led1.off();
if (analogRead(1) > 600) {
led2.on();
pumpEn = 0;
else {
led2.off();
if (pumpOverLock == 0 ) {
pumpEn = 1;
if (analogRead(2) > 600) {
led3.on();
else {
led3.off();
/////////////////////////////////////////////////////////////////////////////////////////////flow control
void pulseCounter()
// Increment the pulse counter
pulseCount++;
void flowRateCheck() // Only process counters once per second
detachInterrupt(sensorInterrupt);
Blynk.virtualWrite(V14 , int(pulseCount)); // Print the integer part of the variable
if (pulseCount < 50 ) {
pumpOverLock = 1;
Blynk.virtualWrite(V30 , pumpOverLock);
pumpEn = 0;
pulseCount = 0;
//////////////////////////////////////////////////////////////////////////////////////startsignal
void startSignal() {
Blynk.virtualWrite(V27 , spEn);
DateTime now = rtc.now();
// delay(100);
if (weekDays[now.dayOfTheWeek()] == 1 && spEn == 1 && spStart == 0) {
if (prog1Hour == now.hour() && prog1Minute == now.minute()) {
spStart = 1;
spNum = 1;
/////////////////////////////////////////////////////////////////////////////////////////spinkler check
void spinklerCheck() {
if (spStart == 1) {
if (Sp[spNum] > 0) {
digitalWrite( spHead[spNum], HIGH);
Sp[spNum]--;
switch (spNum) {
case 1 : Blynk.virtualWrite(V6, 1 );
break;
case 2 : Blynk.virtualWrite(V7, 1 );
break;
case 3 : Blynk.virtualWrite(V8, 1 );
break;
case 4 : Blynk.virtualWrite(V9, 1 );
break;
case 5 : Blynk.virtualWrite(V10, 1 );
break;
case 6 : Blynk.virtualWrite(V11, 1 );
break;
case 7 : Blynk.virtualWrite(V12, 1 );
break;
if (Sp[spNum] == 0) {
switch (spNum) {
case 1 : Blynk.virtualWrite(V6, 0 );
break;
case 2 : Blynk.virtualWrite(V7, 0 );
break;
case 3 : Blynk.virtualWrite(V8, 0 );
break;
case 4 : Blynk.virtualWrite(V9, 0 );
break;
case 5 : Blynk.virtualWrite(V10, 0 );
break;
case 6 : Blynk.virtualWrite(V11, 0 );
break;
case 7 : Blynk.virtualWrite(V12, 0 );
break;
digitalWrite( spHead[spNum], LOW);
spNum++;
if (spNum == 8) {
spStart = 0;
Peter
