Arduino UNO with hm-10 ble module
samsung s9+ with android 10
using blynk 0.61 library
i have used this code:
Arduino BLE Shield (HM-10) Testing Sketch
by JP Liew http://jpliew.com
This program is free software: you can redistribute it and/or modify
it under the terms of the GNU General Public License as published by
the Free Software Foundation, either version 3 of the License, or
(at your option) any later version.
This program is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
GNU General Public License for more details.
You should have received a copy of the GNU General Public License
along with this program. If not, see <http://www.gnu.org/licenses/>.
Changes by FedericoBusero:
- set notification OFF (necessary for Blynk)
#define BUFFER_LENGTH 100
#define LED_PIN 13
SoftwareSerial ble(2, 3); // For Uno, HM10 TX pin to Arduino Uno pin D2, HM10 RX pin to Arduino Uno pin D3
// SoftwareSerial ble(10,11); // For Uno, HM10 TX pin to Arduino Uno pin 10, HM10 RX pin to Arduino Uno pin 11
#define SERIAL_BLE ble
// #define SERIAL_BLE Serial1 // For Mega, ... HM10 TX pin to Arduino RX ping, HM10 TX pin to Arduino RX pin
char buffer[BUFFER_LENGTH]; // Buffer to store response
int timeout = 800; // Wait 800ms each time for BLE to response, depending on your application, adjust this value accordingly
long bauds[] = {9600, 57600}; // common baud rates, when using HM-10 module with SoftwareSerial, try not to go over 57600
long BLEAutoBaud() {
int baudcount = sizeof(bauds) / sizeof(long);
for (int i = 0; i < baudcount; i++) {
for (int x = 0; x < 3; x++) { // test at least 3 times for each baud
Serial.print("Testing baud ");
Serial.println(bauds[i]);
SERIAL_BLE.begin(bauds[i]);
if (BLEIsReady()) {
return bauds[i];
return -1;
boolean BLEIsReady() {
BLECmd(timeout, "AT" , buffer); // Send AT and store response to buffer
if (strcmp(buffer, "OK") == 0) {
return true;
return false;
boolean BLECmd(long timeout, char* command, char* temp) {
long endtime;
boolean found = false;
endtime = millis() + timeout; //
memset(temp, 0, BUFFER_LENGTH); // clear buffer
found = true;
Serial.print("Arduino send = ");
Serial.println(command);
SERIAL_BLE.print(command);
// The loop below wait till either a response is received or timeout
// The problem with this BLE Shield is most of the HM-10 modules do not response with CR LF at the end of the response,
// so a timeout is required to detect end of response and also prevent the loop locking up.
while (!SERIAL_BLE.available()) {
if (millis() > endtime) { // timeout, break
found = false;
break;
if (found) { // response is available
int i = 0;
while (SERIAL_BLE.available()) { // loop and read the data
char a = SERIAL_BLE.read();
// Serial.print((char)a); // Uncomment this to see raw data from BLE
temp[i] = a; // save data to buffer
i++;
if (i >= BUFFER_LENGTH) break; // prevent buffer overflow, need to break
delay(1); // give it a 2ms delay before reading next character
Serial.print("BLE reply = ");
Serial.println(temp);
while ((strlen(temp) > 0) && ((temp[strlen(temp) - 1] == 10) || (temp[strlen(temp) - 1] == 13)))
temp[strlen(temp) - 1] = 0;
return true;
Serial.println("BLE timeout!");
return false;
pinMode(LED_PIN, OUTPUT);
digitalWrite(LED_PIN, LOW);
long baudrate = BLEAutoBaud();
if (baudrate > 0) {
Serial.print("Found BLE baud rate ");
Serial.println(baudrate);
Serial.println("No BLE detected.");
while (1) {}; // No BLE found, just going to stop here
// The following commands are just to demonstrate the shield is working properly,
// in actual application, only call those that are needed by your application.
// Check HM-10 datasheet for the description of the commands.
BLECmd(timeout, "AT+NAME?", buffer);
BLECmd(timeout, "AT+BAUD?", buffer);
BLECmd(timeout, "AT+MODE?", buffer);
BLECmd(timeout, "AT+PASS?", buffer);
BLECmd(timeout, "AT+VERS?", buffer);
BLECmd(timeout, "AT+RADD?", buffer);
BLECmd(timeout, "AT+ADDR?", buffer);
BLECmd(timeout, "AT+TYPE?", buffer);
BLECmd(timeout, "AT+POWE?", buffer); // Show power (should be 2 or 3)
BLECmd(timeout, "AT+NOTI?", buffer); // Check the current notification bit
BLECmd(timeout, "AT+NOTI0", buffer); // Make sure the module doesn't send AT+CONNECT or AT+LOST on the serial line (very important for Blynk users)
// BLECmd(timeout,"AT+NAMEHM10",buffer); // Set the name of the module to HM10
// BLECmd(timeout,"AT+BAUD0",buffer); // Set baudrate to 9600
// BLECmd(timeout,"AT+BAUD1",buffer); // Set baudrate to 19200
// BLECmd(timeout,"AT+BAUD2",buffer); // Set baudrate to 38400
// BLECmd(timeout,"AT+BAUD3",buffer); // Set baudrate to 57600
// BLECmd(timeout,"AT+BAUD4",buffer); // Set baudrate to 115200
Serial.println("----------------------");
Serial.println("Waiting for remote connection...");
void printhex(unsigned char c)
if (c < 0x10) {
Serial.print("0");
Serial.print(c, HEX);
if (SERIAL_BLE.available()) {
char c = (char)SERIAL_BLE.read();
if (isPrintable(c))
Serial.print(c);
Serial.print("[");
printhex(c);
Serial.print("]");
if (c == '1') digitalWrite(LED_PIN, HIGH); // if received character 1 from BLE, set PIN LED_PIN high
if (c == '0') digitalWrite(LED_PIN, LOW); // if received character 0 from BLE, set PIN LED_PIN low
to get the info on the module but I still can’t connect my phone to the board
