Compiling error after upgrading to 3.8.0
Hi, after upgranded to library 3.8.0 I get this error when compilng
fatal error: BlynkSimpleShieldEsp8266_HardSer.h: No such file or directory
 #include <BlynkSimpleShieldEsp8266_HardSer.h>
Before upgrading to 3.7.0 no problem at all. Please some one can helpme?
If rename the include to the existing library BlynkSimpleShieldEsp8266.h I get this other errors
libraries\BlynkESP8266_Lib\ESP8266.cpp.o (symbol from plugin): In function `ESP8266::ESP8266(Stream*)':
(.text+0x0): multiple definition of `ESP8266::checkIPD(String&)'
libraries\BlynkESP8266_HardSer\ESP8266.cpp.o (symbol from plugin):(.text+0x0): first defined here
d:/program files (x86)/arduino/hardware/tools/avr/bin/../lib/gcc/avr/4.9.2/../../../../avr/bin/ld.exe: Disabling relaxation: it will not work with multiple definitions
(.text+0x0): multiple definition of `ESP8266::rx_empty()'
(.text+0x0): multiple definition of `ESP8266::run()'
(.text+0x0): multiple definition of `ESP8266::recvString(String, unsigned long)'
(.text+0x0): multiple definition of `ESP8266::recvString(String, String, unsigned long)'
(.text+0x0): multiple definition of `ESP8266::sATCWMODE(unsigned char, unsigned char)'
(.text+0x0): multiple definition of `ESP8266::qATCWJAP(String&, unsigned char)'
(.text+0x0): multiple definition of `ESP8266::recvString(String, String, String, unsigned long)'
(.text+0x0): multiple definition of `ESP8266::recvFind(String, unsigned long)'
(.text+0x0): multiple definition of `ESP8266::eATSETUART(unsigned long, unsigned char)'
(.text+0x0): multiple definition of `ESP8266::eATCWAUTOCONN(unsigned char)'
(.text+0x0): multiple definition of `ESP8266::eATCIPSTAMAC(String, unsigned char)'
(.text+0x0): multiple definition of `ESP8266::eATCIPSTAIP(String, String, String, unsigned char)'
… and so on for much longer errors listing.
if you downloaded from github you get this error as it is not complete library. download full library from blynk sitedownload from here
Okay, downloade full library from Blynk.cc.
I must change
ESP8266 wifi(EspSerial);
to
ESP8266 wifi(&EspSerial);
to make it work.
i dont know what are you trying to do , but if you are trying to use esp as shield for arduino, just change serial1 to serial for hardware serial example.
I’m using ESP on Serial1 of a Mega.
With the library 3.7 I used
to declare the serial port.
Now with the 3.8 using the declaration above I get a long list of errors during the debug.
So… I must change the declaration to
for make it work.
ok thanks i just tried hardware serial not software .will try software too
Plese check out the latest example. It shows usage.
