I’ve pasted the output from VSCode after I tried a build, I think all the info is in there.
Processing esp32dev (platform: espressif32; board: esp32dev; framework: arduino)
Verbose mode can be enabled via `-v, --verbose` option
CONFIGURATION: https://docs.platformio.org/page/boards/espressif32/esp32dev.html
PLATFORM: Espressif 32 (2.1.0) > Espressif ESP32 Dev Module
HARDWARE: ESP32 240MHz, 320KB RAM, 4MB Flash
DEBUG: Current (esp-prog) External (esp-prog, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa)
PACKAGES:
- framework-arduinoespressif32 3.10004.201016 (1.0.4)
- tool-esptoolpy 1.30000.201119 (3.0.0)
- toolchain-xtensa32 2.50200.80 (5.2.0)
LDF: Library Dependency Finder -> http://bit.ly/configure-pio-ldf
LDF Modes: Finder ~ chain, Compatibility ~ soft
Found 75 compatible libraries
Scanning dependencies...
Dependency Graph
|-- <Blynk> 0.6.7
| |-- <WiFi> 1.2.7
| | |-- <SPI> 1.0
|-- <WiFi> 1.2.7
| |-- <SPI> 1.0
Building in release mode
Compiling .pio/build/esp32dev/src/main.cpp.o
Archiving .pio/build/esp32dev/libb27/libBlynk.a
Indexing .pio/build/esp32dev/libb27/libBlynk.a
In file included from src/main.cpp:8:0:
/home/graeme/Arduino/libraries/Blynk/src/BlynkSimpleEsp32.h: In member function 'void BlynkWifi::connectWiFi(const char*, const char*)':
/home/graeme/Arduino/libraries/Blynk/src/BlynkSimpleEsp32.h:37:14: error: 'class WiFiClass' has no member named 'mode'
WiFi.mode(WIFI_STA);
/home/graeme/Arduino/libraries/Blynk/src/BlynkSimpleEsp32.h:37:19: error: 'WIFI_STA' was not declared in this scope
/home/graeme/Arduino/libraries/Blynk/src/BlynkSimpleEsp32.h:39:34: error: invalid conversion from 'const char*' to 'char*' [-fpermissive]
WiFi.begin(ssid, pass);
In file included from src/main.cpp:6:0:
/home/graeme/arduino-1.8.13/libraries/WiFi/src/WiFi.h:79:9: note: initializing argument 1 of 'int WiFiClass::begin(char*, const char*)'
int begin(char* ssid, const char *passphrase);
/home/graeme/Arduino/libraries/Blynk/src/BlynkSimpleEsp32.h:41:28: error: invalid conversion from 'const char*' to 'char*' [-fpermissive]
WiFi.begin(ssid);
/home/graeme/arduino-1.8.13/libraries/WiFi/src/WiFi.h:60:9: note: initializing argument 1 of 'int WiFiClass::begin(char*)'
int begin(char* ssid);
Compiling .pio/build/esp32dev/FrameworkArduino/IPv6Address.cpp.o
Compiling .pio/build/esp32dev/FrameworkArduino/MD5Builder.cpp.o
Compiling .pio/build/esp32dev/FrameworkArduino/Print.cpp.o
Compiling .pio/build/esp32dev/FrameworkArduino/Stream.cpp.o
Compiling .pio/build/esp32dev/FrameworkArduino/StreamString.cpp.o
Compiling .pio/build/esp32dev/FrameworkArduino/WMath.cpp.o
*** [.pio/build/esp32dev/src/main.cpp.o] Error 1
============================================================================ [FAILED] Took 3.26 seconds ============================================================================
The terminal process "pio 'run', '--environment', 'esp32dev'" terminated with exit code: 1.
Terminal will be reused by tasks, press any key to close it.
The code I was compiling below,
#include <Arduino.h>
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
char pass[] = "YourPassword";
