Hello, is it possible to use the virtual pin name in the BLYNK_WRITE macro from the data structure?
The code crashes, it’s easier and clearer for me than V0 …
Does not work with BLYNK_WRITE(v_pins.test) but work with BLYNK_WRITE(V0)
Error:
sketch_nov22a:20:19: error: expected initializer before ‘.’ token
BLYNK_WRITE(v_pins.test) {
/home/emsit/Arduino/libraries/Blynk/src/Blynk/BlynkHandlers.h:152:30: note: in definition of macro ‘BLYNK_WRITE_2’
void BlynkWidgetWrite ## pin (BlynkReq BLYNK_UNUSED &request, const BlynkParam BLYNK_UNUSED ¶m)
/tmp/arduino_modified_sketch_21883/sketch_nov22a.ino:20:1: note: in expansion of macro ‘BLYNK_WRITE’
#define BLYNK_TEMPLATE_ID "TMPLxxxxxx"
#define BLYNK_DEVICE_NAME "Device"
#define BLYNK_AUTH_TOKEN "XXX"
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
struct BlynkVirtual {
uint8_t test;
BlynkVirtual v_pins {
V0
char pass[] = "YourPassword";
BLYNK_WRITE(v_pins.test) { //work with V0 ...
int pinValue = param.asInt();
