Compilation error: #include nested depth 200 exceeds maximum of 200 (use -fmax-include-depth=depth to increase the maximum
I’m using Esp 8266 and this is my code
After compiling, I’m getting the following error
[Unformatted compiler error message removed by moderator]*
@DEEKSHA Please edit your post, using the pencil icon at the bottom, and add triple backticks at the beginning and end of your code and your compiler error messages so that they display correctly.
I have added ‘’’
Please guide me what to do now
They are the wrong characters. I gave you the correct characters to copy/past, please use them.
Also, the need to be on a separate line to work correctly. Once you use the correct characters you’ll see the difference.
