Olá, preciso de ajuda. tenho um módulo de relê com o esp8266 controlado pelo Blynk, como faço para outra pessoa controlar o “mesmo módulo” de outro celular usando o blynk?. Desde já agradeço pela ajuda.
Share your project. It costs 1000 energy units, which is non-refundable.
The shared users can control the relay, but not edit the app.
If you put the ‘master’ app into edit mode then it is unusable by shared users until you pit it back into play mode again.
Any changes you make to the app will be reflected in the shared app without the need to share again.
