I need emergency help for my project.
I am trying to use two esp32(say A and B) for my project bridged via Blynk. My goal is :
Esp32A will read data from the sensor attached to it and based on the value exceeding threshold ,it will update the value of a virtual pin and the data will be forwared to esp32B which will control Led.
so under same template.i created two devices(diff auth token) and created virtual pin “V5”. For device-A, i made an automation(if value=1) , “forward data path” to the virtual pin of v5 of device B. (also another for value=0)
then when i upload two code to two esp32, i find that the ** latest connected “device” is showed “online” but previously connected device gets offline.** As a result. i am not being able to run both device at the same time. so even if deviceA v5 values updates,no automation occurs to deviceB.
Please help me to solve this. If needed. i can upload my code.
