Hello, I have already written a code to be able to control my relays in a local network. Now I want to combine my code with the Blink project code that is use online blynk servers and be able to control my relays both with Blink servers and by entering my local address. my local sketch is :
/* Create a WiFi access point and provide a web server on it. */
#include <WiFiClient.h>
#include <ESP8266WebServer.h>
#include <EEPROM.h>
#define RELAY 0 // relay connected to GPIO0
#define RELAY2 2
const char *ssid = "***********"; //Enter your WIFI ssid
const char *password = "**********"; //Enter your WIFI password
/* Set these to your desired credentials. */
String stat_str = "--";
String stat_str2 = "--";
ESP8266WebServer server(80);
connected to this access point to see it.
void handleRoot() {
server.send(200, "text/html", "<html><head><meta name=\"viewport\" content=\"width=device-width, initial-scale=1.0\"></head><body bgcolor=\"#cfde2c\"><div style='text-align:center; height:96%; border:10px groove blue; border-radius: 5px;'><strong></strong><h1><i><a style=color:#ff0005; font-size:830%>Shayan Ro0m</a></i></h1></strong><br><br><form action=\"/RELAY_on\" method=\"get\" id=\"form1\"></form><button type=\"submit\" form=\"form1\" value=\"On\"style=\"color:green; background-color:white; font-size:190%; width:230px; margin-left:20px;\" onclick=\'this.form.submit();'>MAHTABI_ON</button><br><br><form action=\"/RELAY_off\" method=\"get\" id=\"form2\"></form><button type=\"submit\" form=\"form2\" value=\"Off\"style=\"color:red; background-color:white; font-size:190%; width:230px; margin-left:20px;\" onclick=\'this.form.submit();'>MAHTABI_OFF</button><h2><a style=color:#ffffff; font-size:330%> MAHTABI_STAT: "+stat_str+"</a><h2><h2><h2><form action=\"/RELAY_on2\" method=\"get\" id=\"form3\"></form><button type=\"submit\" form=\"form3\" value=\"On\"style=\"color:green; background-color:white; font-size:130%; width:210px; margin-left:20px;\" onclick=\'this.form.submit();'>LOSR_ON</button><br><br><form action=\"/RELAY_off2\" method=\"get\" id=\"form4\"></form><button type=\"submit\" form=\"form4\" value=\"Off\"style=\"color:red; background-color:white; font-size:130%; width:210px; margin-left:20px;\" onclick=\'this.form.submit();'>LOSR_OFF</button></h2><a style=color:#ffffff; font-size:830%>LOSR_STAT: "+stat_str2+"</a></h2></body></html>");
void handleSave() {
if (server.arg("pass") != "") {
Serial.println(server.arg("pass"));
// Set your Static IP address
IPAddress local_IP(192, 168, 1, 9);
// Set your Gateway IP address
IPAddress gateway(192, 168, 1, 1);
IPAddress subnet(255, 255, 0, 0);
pinMode(RELAY, OUTPUT);
digitalWrite(RELAY, LOW);
pinMode(RELAY2, OUTPUT);
digitalWrite(RELAY2, LOW);
// Configures static IP address
if (!WiFi.config(local_IP, gateway, subnet)) {
Serial.println("STA Failed to configure");
EEPROM.begin(4096);
int stat = EEPROM.read(0);
digitalWrite(RELAY, stat);
if(stat==0)stat_str="OFF";
if(stat==1)stat_str="ON";
EEPROM.begin(4096);
int stat2 = EEPROM.read(0);
digitalWrite(RELAY2, stat2);
if(stat2==0)stat_str2="OFF";
if(stat2==1)stat_str2="ON";
delay(80000);
Serial.println();
Serial.println("stat: ");
Serial.println(stat);
Serial.println("stat2: ");
Serial.println(stat2);
Serial.print("Configuring access point...");
WiFi.begin(ssid, password);
delay(500);
Serial.print(".");
Serial.println("");
Serial.println("IP address: ");
server.on("/", handleRoot);
server.on ("/save", handleSave);
server.begin();
Serial.println("HTTP server started");
server.on("/RELAY_on", []() {
digitalWrite(RELAY, 1);
Serial.println("on");
EEPROM.write(0,1);//addr,data
EEPROM.commit();
stat_str="ON";
handleRoot();
server.on("/RELAY_off", []() {
digitalWrite(RELAY, 0);
Serial.println("off");
EEPROM.write(0,0);//addr,data
EEPROM.commit();
stat_str="OFF";
handleRoot();
//////////////////////////////////////2
server.on("/RELAY_on2", []() {
digitalWrite(RELAY2, 1);
EEPROM.commit();
stat_str2="ON";
handleRoot();
server.on("/RELAY_off2", []() {
digitalWrite(RELAY2, 0);
EEPROM.commit();
stat_str2="OFF";
handleRoot();
server.handleClient();
and this is my secend code (blynk online server) :
This is a simple demo of sending and receiving some data.
Be sure to check out other examples!
#define BLYNK_TEMPLATE_ID "TMPLlo69-8WE"
#define BLYNK_DEVICE_NAME "google assisstant"
#define BLYNK_AUTH_TOKEN "*********************"
#define RELAY1 0 // relay connected to GPIO0
#define RELAY2 2
char ssid[] = "***********";
char pass[] = "************";
// This function is called every time the Virtual Pin 0 state changes
BLYNK_WRITE(V0)
// Set incoming value from pin V0 to a variable
int value = param.asInt();
// Update state
Blynk.virtualWrite(V1, value);
// This function is called every time the device is connected to the Blynk.Cloud
BLYNK_CONNECTED()
// Change Web Link Button message to "Congratulations!"
Blynk.setProperty(V3, "offImageUrl", "https://static-image.nyc3.cdn.digitaloceanspaces.com/general/fte/congratulations.png");
Blynk.setProperty(V3, "onImageUrl", "https://static-image.nyc3.cdn.digitaloceanspaces.com/general/fte/congratulations_pressed.png");
Blynk.setProperty(V3, "url", "https://docs.blynk.io/en/getting-started/what-do-i-need-to-blynk/how-quickstart-device-was-made");
// This function sends Arduino's uptime every second to Virtual Pin 2.
void myTimerEvent()
Blynk.virtualWrite(V2, millis() / 1000);
pinMode(RELAY1, OUTPUT);
digitalWrite(RELAY1, LOW);
//Blynk.begin(auth, ssid, pass, "blynk.cloud", 80);
//Blynk.begin(auth, ssid, pass, IPAddress(192, 168, 1, 9), 8080);
// to avoid delay() function!
is it possible ?
