please help me…why the instrument do not running well?
* timeinput.ino Demonstrate interaction of Time library with
* Blynk's TimeInput widget.
* App project setup:
* RTC widget (no pin required!!!)
* V1 : Manual/Auto button
* V2: On-off button
* Time Input widget on V8 (All days)
* Button selection for Time Input (All days) on V9
* Time Input widget on V10 (Up to you)
* Button selection for Time Input (Up to you) on V11
#include <ESP8266_Lib.h>
#include <TimeLib.h>
#include <WidgetRTC.h>
#include <DHT.h>
#include <LiquidCrystal.h>
#define DHTPIN 3 // What digital pin we're connected to
LiquidCrystal lcd(13, 8, 7, 6, 5, 4);
const int relay1 = A0;
const int relay2 = A1;
int humLowTrigger;
int tempHighTrigger;
char auth[] = "c2d143cab1xxxxbbfce665e9a2f9e";
char ssid[] = "kangxxhadi";
char pass[] = "poxxron";
#include <WidgetLED.h>
#define TestLED 9 // on board LED pin assignment
char Date[16];
char Time[16];
long startsecondswd; // weekday start time in seconds
long stopsecondswd; // weekday stop time in seconds
long nowseconds; // time now in seconds
bool isFirstConnect = true;
int manual=0;
int oldstatus;
int alldays;
int uptoyou;
SoftwareSerial EspSerial(10, 11); // RX, TX
#include <TimerOne.h> // Avaiable from http://www.arduino.cc/playground/Code/Timer1
volatile int i=0; // Variable to use as a counter volatile as it is in an interrupt
volatile boolean zero_cross=0; // Boolean to store a "switch" to tell us if we have crossed zero
int AC_pin = 12; // Output to Opto Triac
int brightness = 128; // Dimming level (0-128) 0 = on, 128 = 0ff
int freqStep = 75; // This is the delay-per-brightness step in microseconds.
int val = 0;
int autodimmer;
#define ESP8266_BAUD 9600
WidgetRTC rtc;
ESP8266 wifi(&EspSerial);
DHT dht(DHTPIN, DHTTYPE);
void updateHum(int param);
void updateTemp(int param);
BLYNK_WRITE(V5) {
updateHum(param.asInt());
BLYNK_WRITE(V6) {
updateTemp(param.asInt());
void Readdata()
float h = dht.readHumidity();
Blynk.virtualWrite(V15, h);
Blynk.virtualWrite(V16, t);
Blynk.virtualWrite(V25, humLowTrigger);
Blynk.virtualWrite(V24, tempHighTrigger);
if(h < humLowTrigger) {
digitalWrite(relay1, LOW);
Blynk.virtualWrite(V26, 0);
digitalWrite(relay1, HIGH);
Blynk.virtualWrite(V26, 255);
if(t < tempHighTrigger) {
digitalWrite(relay2, HIGH);
Blynk.virtualWrite(V27, 255);
digitalWrite(relay2, LOW);
Blynk.virtualWrite(V27, 0);
void updateHum(int param) {
humLowTrigger = param;
void updateTemp(int param){
tempHighTrigger = param;
void zero_cross_detect() {
zero_cross = true;
i=0;
digitalWrite(AC_pin, LOW); // turn off TRIAC (and AC)
// Turn on the TRIAC at the appropriate time
void dim_check() {
if(zero_cross == true) {
if(i>=brightness) {
digitalWrite(AC_pin, HIGH); // turn on light
i=0; // reset time step counter
zero_cross = false; //reset zero cross detection
else {
i++; // increment time step counter
lcd.begin(16, 2);
dht.begin();
// Print a message to the LCD.
lcd.print("Temp: Humidity:");
pinMode(AC_pin, OUTPUT); // Set the Triac pin as output
attachInterrupt(0, zero_cross_detect, RISING); // Attach an Interupt to Pin 2 (interupt 0)
Timer1.initialize(freqStep); // Initialize TimerOne library
Timer1.attachInterrupt(dim_check, freqStep);
pinMode(relay1, OUTPUT);
pinMode(relay2, OUTPUT);
int humLowTrigger = 65;
int TempHighTrigger = 20;
pinMode(TestLED, OUTPUT);
digitalWrite(TestLED, LOW); // set LED OFF
int mytimeout = millis() / 1000;
while (Blynk.connect() == false) { // try to connect to server for 10 seconds
if((millis() / 1000) > mytimeout + 8){ // try local server if not connected within 9 seconds
break;
rtc.begin();
timer.setInterval(10000L, activetoday); // check every 10 SECONDS if schedule should run today
timer.setInterval(30000L, reconnectBlynk); // check every 30s if still connected to server
BLYNK_CONNECTED() {
if (isFirstConnect) {
Blynk.syncAll();
Blynk.notify("TIMER STARTING!!!!");
isFirstConnect = false;
void activetoday(){ // check if schedule should run today
if(year() != 1970){
if (alldays==1) {
Blynk.syncVirtual(V8); // sync timeinput widget
if (uptoyou==1) {
Blynk.syncVirtual(V10); // sync timeinput widget
void checklastbuttonpressed (){
if(alldays==1){ oldstatus=4; }
if(uptoyou==1){ oldstatus=5; }
void restorelastbuttonpressed (){
if(oldstatus==4){ alldays=1; Blynk.virtualWrite(V9, 1);}
if(oldstatus==5){ uptoyou=1; Blynk.virtualWrite(V11, 1);}
if(oldstatus==6){
alldays=0;
uptoyou=0;
Blynk.virtualWrite(V9, 0);
Blynk.virtualWrite(V11, 0);
BLYNK_WRITE(V3)// slider brillo
int brillo = param.asInt();
if (autodimmer == 0) // If auto dimmer is OFF then set the dimmer according slider value
brightness=brillo;
BLYNK_WRITE(V4) // ON DIMMER AUTO
autodimmer = param.asInt();
if (autodimmer == 1) // If Auto dimmer is ON then calls function Dimmer()
DimmerFunction();
void DimmerFunction()
if (autodimmer >= 1)
for (int i=5; i <= 128; i++) {
brightness=i;
delay(20);
delay(20);
for (int i=128; i >= 5; i--) {
brightness=i;
delay(20);
delay(20);}
// Do nothing
BLYNK_WRITE(V1) // Manual/Auto selection
if (param.asInt()==1) {
manual=1;
checklastbuttonpressed ();
alldays=0;
uptoyou=0;
restorelastbuttonpressed ();
manual=0;
void resetManual()
Blynk.virtualWrite(V1, 0); //Turn OFF Manual Mode Widget
Blynk.virtualWrite(V2, 0); //Turn OFF Button Widget Device
BLYNK_WRITE(V2) // ON-OFF Manual
if (param.asInt()==1) { // boton encendido
if (manual==0){ //está en modo automático
manual=1;
alldays=0;
uptoyou=0;
Blynk.virtualWrite(V1, 1);
digitalWrite(TestLED, HIGH); // set LED ON
Blynk.virtualWrite(V2, 1); //Turn ON Button Widget
} else { //está en modo manual
alldays=0;
uptoyou=0;
}else {
if (manual==0){ //modo automático
manual=1;
alldays=0;
uptoyou=0;
alldays=0;
uptoyou=0;
BLYNK_WRITE(V9) // All days selected
timer.setTimeout(50, resetManual);
timer.setTimeout(50, checklastbuttonpressed);
alldays=1;
uptoyou=0;
alldays=0;
BLYNK_WRITE(V11) // Up to you selected
// timer.setTimeout(50, resetTerminal);
uptoyou=1;
alldays=0;
uptoyou=0;
BLYNK_WRITE(V8)//All days
if (alldays==1) {
TimeInputParam t(param);
int dayadjustment = -1;
if(weekday() == 1){
dayadjustment = 6; // needed for Sunday, Time library is day 1 and Blynk is day 7
if(t.isWeekdaySelected(weekday() + dayadjustment)){ //Time library starts week on Sunday, Blynk on Monday
if (t.hasStartTime()) // Process start time
if (t.hasStopTime()) // Process stop time
for (int i = 1; i <= 7; i++) { // Process weekdays (1. Mon, 2. Tue, 3. Wed, ...)
if (t.isWeekdaySelected(i)) {
nowseconds = ((hour() * 3600) + (minute() * 60) + second());
startsecondswd = (t.getStartHour() * 3600) + (t.getStartMinute() * 60);
if(nowseconds >= startsecondswd){
if(nowseconds <= startsecondswd + 90){ // 90s on 60s timer ensures 1 trigger command is sent
// code here to switch the relay ON
else{
//terminal.println("All Day Device NOT STARTED today");
//terminal.flush();
stopsecondswd = (t.getStopHour() * 3600) + (t.getStopMinute() * 60);
if(nowseconds >= stopsecondswd){
if(nowseconds <= stopsecondswd + 90){ // 90s on 60s timer ensures 1 trigger command is sent
// code here to switch the relay OFF
else{
digitalWrite(TestLED, HIGH); // set LED ON TEST!!!!!
else{
BLYNK_WRITE(V10)//Up to you
if (uptoyou==1) {
if(weekday() == 1){
//Serial.println(startsecondswd); // used for debugging
else{
else{
else{
// nothing to do today, check again in 30 SECONDS time
//terminal.println();
void reconnectBlynk() {
if (!Blynk.connected()) {
if(Blynk.connect()) {
BLYNK_LOG("Reconnected");
BLYNK_LOG("Not reconnected");
DimmerFunction();
lcd.setCursor(0, 1);
// read humidity
//read temperature in Fahrenheit
if (isnan(h) || isnan(t)) {
lcd.print("ERROR");
return;
lcd.print(t);
lcd.setCursor(7,1);
lcd.print(h);
if (Blynk.connected()) {
