I am working on some IOT project with Blynk.
I am using a WW5500 Ethernet module, it works fine with the Blynk test for enthernet2(it connects to the server).
Yesterday my code compiled fine, but suddenly it gives an error.
`Arduino:1.8.13 (Windows Store 1.8.42.0) (Windows 10), Board:"Arduino Mega or Mega 2560,
ATmega2560 (Mega 2560)"
In file included from C:\Users\Isaak\Documents\Arduino\libraries\Blynk\src/Blynk/BlynkApi.h:16:0,
from C:\Users\Isaak\Documents\Arduino\libraries\Blynk\src/BlynkApiArduino.h:14,
from C:\Users\Isaak\Documents\Arduino\libraries\Blynk\src/Adapters/BlynkEthernet.h:24,
from C:\Users\Isaak\Documents\Arduino\libraries\Blynk\src/BlynkSimpleEthernet2.h:20,
from C:\Users\Isaak\Desktop\Arduino_Ethernet2\Arduino_Ethernet2.ino:4:
C:\Users\Isaak\Documents\Arduino\libraries\Blynk\src/Blynk/BlynkParam.h: In instantiation of void
BlynkParam::add_multi(T) [with T = float (*)(); Args = {}]:
C:\Users\Isaak\Documents\Arduino\libraries\Blynk\src/Blynk/BlynkApi.h:81:9: required from void
BlynkApi<Proto>::virtualWrite(int, Args ...) [with Args = {float (*)()}; Proto =
BlynkProtocol<BlynkArduinoClientGen<Client> >]'
C:\Users\Isaak\Desktop\Arduino_Ethernet2\Arduino_Ethernet2.ino:128:40: required from here
C:\Users\Isaak\Documents\Arduino\libraries\Blynk\src/Blynk/BlynkParam.h:112:9: error: no matching
function for call to add(float (*&)())
add(last);
C:\Users\Isaak\Documents\Arduino\libraries\Blynk\src/Blynk/BlynkParam.h:231:10: note: candidate:
void BlynkParam::add(int) <near match>
void BlynkParam::add(int value)
conversion of argument 1 would be ill-formed:
C:\Users\Isaak\Documents\Arduino\libraries\Blynk\src/Blynk/BlynkParam.h:239:10: note: candidate:
void BlynkParam::add(unsigned int) <near match>
void BlynkParam::add(unsigned int value)
C:\Users\Isaak\Documents\Arduino\libraries\Blynk\src/Blynk/BlynkParam.h:247:10: note: candidate:
void BlynkParam::add(long int) <near match>
void BlynkParam::add(long value)
C:\Users\Isaak\Documents\Arduino\libraries\Blynk\src/Blynk/BlynkParam.h:255:10: note: candidate:
void BlynkParam::add(long unsigned int) <near match>
void BlynkParam::add(unsigned long value)
C:\Users\Isaak\Documents\Arduino\libraries\Blynk\src/Blynk/BlynkParam.h:263:10: note: candidate:
void BlynkParam::add(long long int) <near match>
void BlynkParam::add(long long value) // TODO: this currently adds just a long
C:\Users\Isaak\Documents\Arduino\libraries\Blynk\src/Blynk/BlynkParam.h:271:10: note: candidate:
void BlynkParam::add(long long unsigned int) <near match>
void BlynkParam::add(unsigned long long value) // TODO: this currently adds just a long
exit status 1
Fout bij het compileren voor board Arduino Mega or Mega 2560`
It looks like it has to do with the library, but i didn’t mess with it.
I recompiled it many times (some other topics said that that might work).
I deleted and reinstalled the lib, but without success.
If anyone knows how to solve this issue, i would really appreciate it!
The title of your topic is “New Wemos D1 mini keeps disconecting form the blynk cloud”. yet you aren’t using a Wemos D1 Mini, and your issue is that you can’t get your sketch to compile as opposed to your device keeps disconnecting.
What’s this all about?
We need to see your code, and when you post it you MUST format it correctly by placing triple backticks at the beginning and end of your code so that it displays correctly.
Copy and past these exact characters if necessary.
If you post incorrectly formatted code it will be deleted.
I assumed that some of the .h files were tabs that include custom code.
If not then I doubt that many people will be willing to go and track down these libraries and install them so that they can compile your code for you to see if they experience the same error.
The error is in one of the Blynk libraries, I tested it and if I delete all the other libraries and code that has nothing to do with blynk. and it still gave that error message.
whats true tho is that I created 4 tabs (was simpeler to edit things), the code that you see is the same code but in one tab… (the code i posted gave the same error as the origenal).
If the Blynk example for the W5500 compiles correctly then don’t you think that it points to an issue with your code as opposed to an issue with the Blynk library installation?
If there is a library issue then it’s probably going to be with the Ethernet2 library.
This should be installed via the IDE’s Library Manager which will normally place the files in Documents > Arduino > libraries > Ethernet2, but your appear to be on your desktop…
