hi everyone, please someone can transform my code for me to work with blynk.
in addition I want to integrate a temperature and humidity sensor DHT22
// VCC -> 3V3 or 5V
// GND -> GND
// SCL -> SCL (A5 on Arduino Uno, Leonardo, etc or 21 on Mega and Due, on esp8266 free selectable)
// SDA -> SDA (A4 on Arduino Uno, Leonardo, etc or 20 on Mega and Due, on esp8266 free selectable)
// ADD -> (not connected) or GND (I2C Address is 0x23)
// ADD pin is used to set sensor I2C address. If it has voltage greater or equal to
// 0.7VCC voltage (e.g. you've connected it to VCC) the sensor address will be
// 0x5C. In other case (if ADD voltage less than 0.7 * VCC) the sensor address will
// be 0x23 (by default).
// I2C setting
#include <Wire.h>
// 128x64 OLED setting
//#include <Adafruit_GFX.h>
//#include <Adafruit_SSD1306.h>
// Power
#define BH1750_POWER_DOWN 0x00 // No active state
#define BH1750_POWER_ON 0x01 // Waiting for measurement command
#define BH1750_RESET 0x07 // Reset data register value - not accepted in POWER_DOWN mode
// Measurement Mode
#define CONTINUOUS_HIGH_RES_MODE 0x10 // Measurement at 1 lux resolution. Measurement time is approx 120ms
#define CONTINUOUS_HIGH_RES_MODE_2 0x11 // Measurement at 0.5 lux resolution. Measurement time is approx 120ms
#define CONTINUOUS_LOW_RES_MODE 0x13 // Measurement at 4 lux resolution. Measurement time is approx 16ms
#define ONE_TIME_HIGH_RES_MODE 0x20 // Measurement at 1 lux resolution. Measurement time is approx 120ms
#define ONE_TIME_HIGH_RES_MODE_2 0x21 // Measurement at 0.5 lux resolution. Measurement time is approx 120ms
#define ONE_TIME_LOW_RES_MODE 0x23 // Measurement at 4 lux resolution. Measurement time is approx 16ms
// I2C Address
#define BH1750_1_ADDRESS 0x23 // Sensor 1 connected to GND
#define BH1750_2_ADDRESS 0x5C // Sensor 2 connected to VCC
// Set the LCD address to 0x27 for a 20 chars and 4 line display
LiquidCrystal_I2C lcd(0x27, 20, 4);
// LED Blink
#define LED_PIN 12
// Definition of Variable
int16_t s_en = 4; // For MUX
int16_t s0 = 5; // For MUX
int16_t s1 = 6; // For MUX
int16_t s2 = 7; // For MUX
int16_t RawData; // RawData of BH1750
int16_t SensorValue[4]; // Sensor Value of BH1750
long h, m, s; // Hour, Minute, Second
boolean blinkState = false;
Wire.begin();
Serial.begin(115200); // Baud Rate
// initialize the LCD,
lcd.init();
// Turn on the blacklight and print a message.
lcd.backlight();
lcd.clear();
pinMode(s_en, OUTPUT);
pinMode(s0, OUTPUT);
pinMode(s1, OUTPUT);
pinMode(s2, OUTPUT);
digitalWrite(s_en, HIGH);
digitalWrite(s0, HIGH);
digitalWrite(s1, HIGH);
digitalWrite(s2, HIGH);
pinMode(LED_PIN, OUTPUT);
digitalWrite(LED_PIN, HIGH);
digitalWrite(s_en, LOW); // Enabling the Enable Switch
for(int i = 0; i < 4; i++){
readMux(i);
init_BH1750(BH1750_1_ADDRESS, CONTINUOUS_HIGH_RES_MODE);
delay(120);
RawData_BH1750(BH1750_1_ADDRESS);
SensorValue[i] = RawData / 1.2;
//delay(20);
// Serial Printing
Serial.print("Sensor_1 = "); Serial.print(SensorValue[0]);
Serial.print(" | Sensor_2 = "); Serial.print(SensorValue[1]);
Serial.print(" | Sensor_3 = "); Serial.print(SensorValue[2]);
Serial.print(" | Sensor_4 = "); Serial.println(SensorValue[3]);
// 128x64 OLED Display
//display.setTextSize(1);
//display.setTextColor(WHITE);
lcd.setCursor (0,0);
//display.println(String(h) + ":" + String(m) + ":" + String(s));
lcd.print("Sensor_1 = " + String(SensorValue[0]));
lcd.setCursor (0,1);
lcd.print("Sensor_2 = " + String(SensorValue[1]));
lcd.setCursor (0,2);
lcd.print("Sensor_3 = " + String(SensorValue[2]));
lcd.setCursor (0,3);
lcd.print("Sensor_4 = " + String(SensorValue[3]));
delay(2000);
lcd.clear();;
void init_BH1750(int ADDRESS, int MODE){
//BH1750 Initializing & Reset
Wire.beginTransmission(ADDRESS);
Wire.write(MODE); // PWR_MGMT_1 register
Wire.endTransmission(true);
void RawData_BH1750(int ADDRESS){
Wire.requestFrom(ADDRESS,2,true); // request a total of 2 registers
RawData = Wire.read() << 8 | Wire.read(); // Read Raw Data of BH1750
int readMux(int channel) {
int controlPin[] = {s0, s1, s2};
int muxChannel[8][3] = {
{0,0,0}, //channel 0
{1,0,0}, //channel 1
{0,1,0}, //channel 2
{1,1,0}, //channel 3
{0,0,1}, //channel 4
{1,0,1}, //channel 5
{0,1,1}, //channel 6
{1,1,1}, //channel 7 //loop through the 3 Signals
for(int i = 0; i < 3; i++){ // Connecting MUX Channel
digitalWrite(controlPin[i], muxChannel[channel][i]);
