I am just starting with Blynk and am implementing it in an existing project that uses a sim7000 GSM.
This project runs multiple tasks (all on core 1) and I have implemented Blynk to also to run in a task (on core 0) so all can run more or less in “parallel”.
The code is event based (like Blynk gets a notification when another object wants to send a message) but there are some processor time heavy components…
Problems I am having are cmd errors (and thus reconnects).
I am trying to play with the following defines to make sure other tasks also get processor time and blynk is not starved (but to be honest I am not exactly aware if these defines have the result I am looking for):
#define TINY_GSM_YIELD_MS 1
#define BLYNK_RUN_YIELD() { delay(1);}
#define BLYNK_SEND_CHUNK 64
#define BLYNK_SEND_THROTTLE 20
I first initialize blynk, then the task is started which runs the blynk.update and processes messages that need to be sent (which are queued).
Below the code parts I use related to blynk and some logs.
Hope anybody can point me in the right direction and help troubleshoot/tweak this.
thx!
void BlynkNodeSim7000::initialize() {
restartModem();
Blynk.begin(auth, *gsmGps, gprsApn, gprsUser, gprsPw, "blynk.cloud", 80);
blynkQueue = xQueueCreate(10, sizeof(blynkMsg));
blynkTask.resumeTask();
esp_reset_reason_t reason = esp_reset_reason();
queueVpinCharMsg(254, GetESPResetReason(reason).c_str());
queueVpinIntMsg(255, reason);
sensorActive = true;
bool BlynkNodeSim7000::restartModem() {
//TODO what if init starts, then it will never come up
if (!gsmGps->restart()) {
if (!gsmGps->init()) {
log_w("Failed to (re-)start an init modem");
return 0;
return 1;
void BlynkNodeSim7000::update() {
void BlynkNodeSim7000::virtualWrite(uint8_t vPin, char* value) {
Blynk.virtualWrite(vPin, value);
// log_d("vw %s", value);
void BlynkNodeSim7000::notification(Sense::IObservable* obs) {
Sense::INode* node = obs->getValueObject();
blynkMsg msg;
msg.vPin = obs->getId();
node->getReadableValue(msg.value, 30);
xQueueSend(blynkQueue, &msg, 100);
void BlynkNodeSim7000::queueVpinIntMsg(uint8_t vPin, uint8_t value) {
blynkMsg msg;
msg.vPin = vPin;
sprintf(msg.value, "%d", value);
void BlynkNodeSim7000::queueVpinFloatMsg(uint8_t vPin, float value) {
blynkMsg msg;
msg.vPin = vPin;
sprintf(msg.value, "%f", value);
void BlynkNodeSim7000::queueVpinCharMsg(uint8_t vPin, const char value[]) {
blynkMsg msg;
msg.vPin = vPin;
memcpy(msg.value, value, 30);
void blynkControllTask(void* pvParameters) {
BlynkNodeSim7000* BlynkNodeSim7000Obj = reinterpret_cast<BlynkNodeSim7000*>(pvParameters);
struct blynkMsg {
uint16_t vPin = 0;
char value[30];
blynkMsg msg;
BlynkNodeSim7000Obj->update();
if (Blynk.connected() && xQueueReceive(BlynkNodeSim7000Obj->blynkQueue, &msg, ( TickType_t ) 0 ) ) {
BlynkNodeSim7000Obj->virtualWrite(msg.vPin, msg.value);
Logs:
[D][TaskUtils.cpp:26] internalTask(): Creating Task [blynkTask] (suspended)
[D][TaskUtils.cpp:42] internalTask(): Task [blynkTask] suspended
[11872]
___ __ __
/ _ )/ /_ _____ / /__
/ _ / / // / _ \/ '_/
/____/_/\_, /_//_/_/\_\
/___/ v1.0.1 on ESP32
[D][BlynkGsmClient.h:113] begin(): begin
[11977] Connecting to network...
[12023] Network: vodafone NL 1nce.net
[12023] Connecting to iot.1nce.net ...
[16224] Connected to GPRS
[16253] Connecting to blynk.cloud:80
[17004] <[1D|00|01|00] xxxxxxxxxxxxxxxxxxxxxxxx
[17427] >[00|00|01|00|C8]
[17427] Ready (ping: 374ms).
[17497] <[11|00|02|00]Rver[00]1.0.1[00]h-beat[00]60[00]buff-in[00]1024[00]dev[00]ESP32[00]con[00]TinyGSM[00]buil
[17548] <d[00]Dec 9 2021 14:49:48[00]
[D][TaskUtils.cpp:84] resumeTask(): Task [blynkTask] resumed
[17664] <[14|00|03|00|12]vw[00]254[00]ESP_RST_WDT
[17777] <[14|00|04|00|08]vw[00]255[00]7
[17898] >[00|00|02|00|C8]
[52789] <[14|00|05|00|09]vw[00]120[00]02
[62497] <[14|00|06|00|09]vw[00]120[00]32
[70008] <[14|00|07|00|09]vw[00]120[00]02
[77909] <[06|00|08|00|00]
[78169] >[00|00|08|00|C8]
[131302] <[14|00|09|00|09]vw[00]120[00]01
[138181] <[06|00|0A|00|00]
[138464] >[00|00|0A|00|C8]
[198274] <[06|00|0B|00|00]
[199302] Cmd error
[203294] Connecting to blynk.cloud:80
[203543] <[1D|00|01|00] xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
[203738] >[00|00|01|00|C8]
[203739] Ready (ping: 149ms).
[203807] <[11|00|02|00]Rver[00]1.0.1[00]h-beat[00]60[00]buff-in[00]1024[00]dev[00]ESP32[00]con[00]TinyGSM[00]buil
[203855] <d[00]Dec 9 2021 14:49:48[00]
[204115] >[00|00|02|00|C8]
[263952] <[06|00|03|00|00]
[264966] >[00|00|03|00|C8]
[324804] <[06|00|04|00|00]
[325715] >[00|00|04|00|C8]
[385553] <[06|00|05|00|00]
[386595] >[00|00|05|00|C8]
[446404] <[06|00|06|00|00]
[447319] >[00|00|06|00|C8]
[507157] <[06|00|07|00|00]
[508163] >[00|00|07|00|C8]
[508165] <[14|00|08|00|09]vw[00]120[00]02
[518329] <[14|00|09|00|09]vw[00]120[00]32
[535759] <[14|00|0A|00|09]vw[00]120[00]02
[536788] Cmd error
[539824] Connecting to blynk.cloud:80
[540581] <[1D|00|01|00] xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
[540872] >[00|00|01|00|C8]
[540873] Ready (ping: 246ms).
[540941] <[11|00|02|00]Rver[00]1.0.1[00]h-beat[00]60[00]buff-in[00]1024[00]dev[00]ESP32[00]con[00]TinyGSM[00]buil
[540989] <d[00]Dec 9 2021 14:49:48[00]
[541262] >[00|00|02|00|C8]
[597035] <[14|00|03|00|09]vw[00]120[00]01
[598064] Cmd error
[601098] Connecting to blynk.cloud:80
[602782] <[1D|00|01|00] xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
[603358] >[00|00|01|00|C8]
[603359] Ready (ping: 531ms).
[603427] <[11|00|02|00]Rver[00]1.0.1[00]h-beat[00]60[00]buff-in[00]1024[00]dev[00]ESP32[00]con[00]TinyGSM[00]buil
[603475] <d[00]Dec 9 2021 14:49:48[00]
[604265] >[00|00|02|00|C8]
[663527] <[06|00|03|00|00]
[664555] Cmd error
[668546] Connecting to blynk.cloud:80
[671644] <[1D|00|01|00] xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
[672112] >[00|00|01|00|C8]
[672113] Ready (ping: 423ms).
[672181] <[11|00|02|00]Rver[00]1.0.1[00]h-beat[00]60[00]buff-in[00]1024[00]dev[00]ESP32[00]con[00]TinyGSM[00]buil
[672229] <d[00]Dec 9 2021 14:49:48[00]
[672812] >[00|00|02|00|C8]
[732277] <[06|00|03|00|00]
[733346] >[00|00|03|00|C8]
[793029] <[06|00|04|00|00]
[794057] Cmd error
[798099] Connecting to blynk.cloud:80
[803752] <[1D|00|01|00] xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
[806162] >[00|00|01|00|C8]
[806163] Ready (ping: 2365ms).
[806291] <[11|00|02|00]Rver[00]1.0.1[00]h-beat[00]60[00]buff-in[00]1024[00]dev[00]ESP32[00]con[00]TinyGSM[00]buil
[806339] <d[00]Dec 9 2021 14:49:48[00]
[806949] >[00|00|02|00|C8]
