Hi there,
I’m fairly new to Blynk and teensy. I’ve some experience with Arduino nano, uno and pro mini. For my new project i’d like to utilize a teensy 3.2, because of its capabilities and its form-factor. I took the teensy 3.2, because the specs told me, that it is capable of powering the esp01. In order to flash the ESPI used a dedicated serial-programmer.
But I’ve tried for hours to get the Blynk Blink and Blynk Push Data examples running and everything I was trying, I always get an “Cmd error” early after communication start. My app says ‘wasn’t online yet’. My ESP01 is connected to my local wifi. I can successful send pings to the IP shown in the log.
I flashed firmware of the ESP to
AT version:1.1.0.0(May 11 2016 18:09:56)
SDK version:1.5.4(baaeaebb) compile time:May 20 2016 15:06:44
as recommended at http://help.blynk.cc/en/articles/605485-esp8266-with-at-firmware .
As far as I understand the log output, the ‘cmd error occurs’, when trying to send my auth-token (XXX) to the blynk-cloud.
I don’t think there is a problem in the serial communication, because the initial log output seems to me the two devices (teensy and esp01) can talk to each other.
I’ve already read a ton of posts here. I’ve already changed bauds to higher and lower values, but now I run out of ideas…
The Wiring:
Power Supply over Teensy-USB-Port
Teensy Pin --> ESP Pin
GND --> GND
0 (RX1) --> TXD
1 (TX1) --> RXD
3.3V --> Vcc --> CH_PD
The log output:
[4310]
___ __ __
/ _ )/ /_ _____ / /__
/ _ / / // / _ \/ '_/
/____/_/\_, /_//_/_/\_\
/___/ v0.6.1 on Teensy 3.2/3.1
[4810] Connecting to YYY
[7914] AT version:1.1.0.0(May 11 2016 18:09:56)
OK
[11057] +CIFSR:STAIP,"192.168.179.4"
+CIFSR:STAMAC,"48:3f:da:00:91:17"
[11057] Connected to WiFi
[21149] <[1D|00|01|00] XXX
[31184] Cmd error
[46293] <[1D|00|01|00] XXX
[56328] Cmd error
The sketch:
http://twitter.com/blynk_app
WARNING!
It's very tricky to get it working. Please read this article:
http://help.blynk.cc/hardware-and-libraries/arduino/esp8266-with-at-firmware
This example shows how value can be pushed from Arduino to
the Blynk App.
NOTE:
BlynkTimer provides SimpleTimer functionality:
http://playground.arduino.cc/Code/SimpleTimer
App project setup:
Value Display widget attached to Virtual Pin V5
#define BLYNK_DEBUG
#define PIN02 2
#include <ESP8266_Lib.h>
char auth[] = "XXX";
char ssid[] = "YYY";
char pass[] = "ZZZ";
#define EspSerial Serial1
//#include <SoftwareSerial.h>
// Your ESP8266 baud rate:
#define ESP8266_BAUD 19200
ESP8266 wifi(&EspSerial);
void myTimerEvent()
Serial.println("myTimerEvent");
pinMode(PIN02, OUTPUT);
// Test Output on Pin
for (int i =0; i <4; i++) {
digitalWrite(2, HIGH);
delay(500);
digitalWrite(2, LOW);
delay(500);
// Set ESP8266 baud rate
//Blynk.begin(auth, wifi, ssid, pass, "blynk-cloud.com", 80);
//Blynk.begin(auth, wifi, ssid, pass, IPAddress(192,168,1,100), 8080);
// timer.setInterval(1000L, myTimerEvent);
// timer.run(); // Initiates BlynkTimer
There is a warning while compiling:
BlynkSimpleShieldEsp8266.h:45:27: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
if (buffer.free() < len) {
