Clone a cloned project?
I’ve recompiled the project, try again with https://www.dropbox.com/s/8fhwj4scwfy575a/blynk_app-debug-log.apk?dl=0
@BlynkAndroidDev that version is fine and I have sent you the first debug log.
@BlynkAndroidDev I think the debug version has a problem with virtual pin numbers > 31.
I have about a dozen pins numbered > 31 and I noticed the pin assignments had disappeared in the app. I have just reassigned them and sent you log file number 5 with the latest cloning failure.
Log file is getting quite big, now 10MB.
Logs are large due to probably several active projects and logging of the communication as well. I’ve found the ‘why’ of the failing of qr generation, will try to fix it soon.
@BlynkAndroidDev any news on a fix for the cloning bug?
Hi, we are working currently on another feature, but i think we’ll soon release some bugfix build with a fix for this issue. Somehow you are reaching limit for the QR’s text max size o_O
