HI:
Just getting stated with Blynk and would like to use it’s Client.jar instead of an iPad but can’t find were the Client.jar is located. I’ve installed my local server and have been using an iPad but having everything together with greatly help.
Thanks.
Nivlek
Also were are my Blynk apps located when using a local server? Would like to back them up.
Not sure what you are looking for here… I have Local Server and there is no such file that I can find. And as for using it instead of an iPad?? I think what you are looking for is a IOS emulator program instead (if there is such a thing for IOS)… Or try MEmu for a good Android emulator.
I think they are all stored as text in your you@email.com.Blynk user file, and server made backups of such are stored in the Blynk/Backup folder… Or just backup the QR files from Cloning via the app (again I am unsure if that is available in IOS).
I thought I read that there was a emulator called client.jar that allowed using PC instead of tablet device. My bad.
I think my error is an email issue.
23:08:45.534 ERROR- Error sending email auth token to user : xxxx@trahreg.com. Error: Could not convert socket to TLS
Any idea what is causing it? Using local server. Server starts without errors.
Thanks.
Some Googling of your error shows AV and/or certificate issues, and searching this forum for same error points to your computers AV being the most likely culprit
In case you are using gmail on the Local Server you are limited with 500 mails per day (by google). Other providers may have similar limitations, so please be careful.
