Clearing text input widget
I’m trying to clear a text input widget from my sketch as soon as the value is sent. I’ve tried this but it doesn’t have any effect:
BLYNK_WRITE(V4) {
   Blynk.virtualWrite(V4, "");
Is there a way to do this? Thanks!
Have you tried…
Blynk.virtualWrite(V4, " ");
(with a space between the quotes)?
If that doesn’t work then what app version and OS are you using?
That does work, Pete. Sort of … What I’d really like is a way to clear the field, not replace with a space. The space is preventing the hint from reappearing, and it’s adding a space to the front of my strings (unless I remember to hit the “delete” key, of course). Not very pretty. I was hoping there was a way to really null out the field. A nice feature for the input widgets (that I think would be widely used) would be a “clear on send” option. But since that’s not there, I was hoping there was a way to do it from the sketch.
What about an escape backspace delete character…
Blynk.virtualWrite(V4, "\b");
Nope. But worth a try! Thanks anyway, Pete.
to my knowledge this problem is not resolved
This is quite annoying, because the space will be left after a user input, without any server-side strategy to guess whether it should be deleted or not.
adding a method (“clear”, “clean”, …) to get a clean empty input would be more than necessary, don’t you think ?
True, Any method to clear text input field and see that hint again…
Pete, do we have anything to clear the input already?
No.
No solution implemented for this yet?
It seems like a \n works fine.
Blynk.virtualWrite(pin, “\n”);
