Est-il possible de changer l’état d’un bouton Blynk en appuyant sur un bouton physique broché à un ESP8266 ?
J’ai essayé avec un Blynk.virtualWrite(V1,LOW);
Cependant dans l’application le bouton passe bien de on à off mais seulement en apparence. Le code de l’ESP ne perçoit pas de changement d’état. Celui-ci reste à 1.
Comment faire pour lire un 0 après avoir demander le changement d’état ?
This example shows how to synchronize Button widget
and physical button state.
App project setup:
Button widget attached to V2 (Switch mode)
#define BLYNK_TEMPLATE_ID "TMPLxxxxxx"
#define BLYNK_DEVICE_NAME "Device"
#define BLYNK_AUTH_TOKEN "YourAuthToken"
char pass[] = "YourPassword";
// Set your LED and physical button pins here
const int ledPin = 7;
const int btnPin = 8;
void checkPhysicalButton();
int ledState = LOW;
int btnState = HIGH;
// Every time we connect to the cloud...
BLYNK_CONNECTED() {
Blynk.syncVirtual(V2);
// Alternatively, you could override server state using:
//Blynk.virtualWrite(V2, ledState);
// When App button is pushed - switch the state
BLYNK_WRITE(V2) {
ledState = param.asInt();
digitalWrite(ledPin, ledState);
if (digitalRead(btnPin) == LOW) {
if (btnState != LOW) {
// Toggle LED state
ledState = !ledState;
// Update Button Widget
btnState = LOW;
btnState = HIGH;
//Blynk.begin(auth, ssid, pass, "blynk.cloud", 80);
pinMode(ledPin, OUTPUT);
pinMode(btnPin, INPUT_PULLUP);
// Setup a function to be called every 100 ms
timer.setInterval(100L, checkPhysicalButton);
@John93 please edit your post, using the pencil icon at the bottom, and add triple backticks at the beginning and end of your code so that it displays correctly.
