Change AUTH but the old AUTH still working
Dear @Dmitriy, @vshymanskyy, @BlynkAndroidDev
I discovered something strange. I have all the latest versions and I working using the public Blynk Server.
In order to test something, using the Android App, I issued a new AUTH code. Everything done properly but without sent the updated sketch ( with the new AUTH code ) I see the old one working fine…! I left 15 minutes now and it is still working, the hardware has the old AUTH code and the Android App has the new AUTH code but still working! Is this correct? At the Android Blynk App, I stopped the particular project and started several times without change in the described above behavior…
Please comment.
Thanks and Best Regards,
Mike Kranidis
Hello. Yes, while hardware is connected it is still be working with old token until next “login” command. However, it is good point and should be fixed. Thanks for reporting.
Very nice. Fastest patching!
