I was playing with the timer widget this afternoon and it seems that I can’t change either the start or end time to 12:Anything PM- only AM. I can SOMETIMES get it to stick on PM, but when I go Back to the main widget dashboard, it goes back to 12:XX AM. If I change the time to a number other than 12 (haven’t tested them all), like 1:01, I can change from AM to PM. I’m using Android.
Thank you for reporting. It is already fixed. Will be available in next release.
Ok. Thank you for testing.
Tried the latest Android app last night.
I normally have my Android set on a 24 hour clock but if I change it to AM / PM settings I can’t select 12:XX either.
The other issue is that there is no 00 hours available in AM / PM mode so you wouldn’t be able to set the time at 00:30:00.
I think the timer was designed for a 24 hour clock because in this mode all times are available with 23:59:59 correctly rolling over to 00:00:00.
guys,
i’ve found why this happens, but i have not time to fix it now. we are preparing a huge update, which will be released by the end of next week, and it will be with a fix for this issue.
sorry, for this inconvenience - on next week it will be fixed
timer should be fixed in last builds
