Hello, everyone! I’m new here so hi once again!
I had a doubt, I’m using Node MCU ESP 8266 and MQ 135 gas sensor as my hardware components. I aim to send my sensor readings to my Blynk template, but I can’t seem to do it. I always get an error - exit status 1
I’m tried everything, from changing my USB cable to install the CH9102 driver. I still can’t get rid of that error. For reference, this is my code, I tried to keep it simple -
char auth[] = "Token"; // Enter your Blynk authentication token here
char ssid[] = "WiFI"; // Enter your WiFi network name
char pass[] = "Password"; // Enter your WiFi password
#define GAS_SENSOR_PIN A0
float gasValue = analogRead(GAS_SENSOR_PIN);
Serial.print("Gas Value: ");
Serial.println(gasValue);
Blynk.virtualWrite(V5, gasValue); // Send gas value to virtual pin V5 on the Blynk app
delay(1000); // Adjust delay as per your requirement
Can someone pls help me out with this ?
@Spidey Please edit your post, using the pencil icon at the bottom, and add triple backticks at the beginning and end of your code so that it displays correctly.
@PeteKnight Thank you so much for looking into this, I’ve done the necessary changes. If you have a sec, could you give me a hand figuring out where I might’ve gone wrong?
Aabha
If this is your full sketch then you’ll be getting a compilation error message that says “#error “Please specify your BLYNK_TEMPLATE_ID and BLYNK_TEMPLATE_NAME” before you get the “exit status 1” message.
Posting your full compiler message (as text, with triple backticks) will help identify the issue.
39 | #error "Please specify your BLYNK_TEMPLATE_ID and BLYNK_TEMPLATE_NAME"
exit status 1
Compilation error: exit status 1```
this is all that I get, and even when I change the code and write the template id and name I still get the same 2 errors
@PeteKnight I saw one of your previous interactions with a member and they mentioned using the previous version of Blynk, I was able to connect my device. Thank you so much for your help !!! Really appreciate it!
