OK, so I uninstalled the BLYNK app and was able to install the -log version. I messed with it a bit, trying to resize without success and with dragging it to the bottom and then resizing it. I sent the log.
Please let me know if I did it correct, or if I need to redo it.
I’m investigating the logs, by the way, I see receiving of strange wrong messages by the app - smth like pin writes but without pin params, could you attach here also you sketch?
I see several situations with not showing resize:
- when there is a touch not on the resize frame - and app hides resize frame
- in case of minimal size of the widget: after it’s drag and not available space for resize to a larger size
Could you check does resize is not working in case of a minimal size of the widget? Maybe our check for a resize in such case fails under some circumstances
