Using the github bylnkkk for raspberry pi 3 (via ethernet) on python3 (https://github.com/blynkkk/lib-python), (0.2.6) it connects okay (using blynk server) and I can set the value of a virtual pin, but I just can’t figure
out how to read the value of one or use an interrupt / thread / function to run when its state is changed.
Writing 1 to virtual pin 4 works:
blynk.virtual_write(4, 1)
but neither of these work: (I don’t get anything printed when I change the state of V4)
@blynk.handle_event('read V4')
def read_virtual_pin_handler(pin):
print("po")
#print(READ_PRINT_MSG.format(pin))
#print(blynk.virtual_sync(pin))
#print(sensor_data)
blynk.notify('Warning critical value')
#blynk.virtual_write(pin, random.randint(0, 255))
@blynk.handle_event('write V4')
def write_virtual_pin_handler(pin, value):
print(WRITE_EVENT_PRINT_MSG.format(pin, value))
blynk.notify('bpush')
Any ideas how I can use python & blynk with my pi? Thanks
