Hi, Newbie here. I can’t migrate to the New Blynk, can anyone please help me step by step on how to do that ? I’ve read the Full Guide but it seems that it don’t really work for the code, i don’t undertand which part of the code that i need to change or add.
• NodeMCU ESP8266 + WiFi.
• Android 11
• Blynk server
• Blynk Library version 1.1.0
• This is the sketch code
#include <MFRC522.h>
#include <EEPROM.h>
#define SS_PIN 4 //D2
#define RST_PIN 5 //D1
#define BTN_PIN 0 //D3
#define SLN_PIN 2 //D4
MFRC522 mfrc522(SS_PIN, RST_PIN);
unsigned long uidDec, uidDecTemp;
int ARRAYindexUIDcard;
int EEPROMstartAddr;
long adminID = 1122539531;
bool beginCard = 0;
bool addCard = 1;
bool skipCard = 0;
int LockSwitch;
unsigned long CardUIDeEPROMread[] = {0, 1, 2, 3, 4, 5, 6, 7, 8, 9};
int PiezoPin = 15; //D8
char auth[] = "fXl7Pz7F9mcRWGXahoByX2vir2o9QUnz";
char ssid[] = "---";
char pass[] = "---";
WidgetLCD lcd(V0);
pinMode(SLN_PIN, OUTPUT); digitalWrite(SLN_PIN, LOW);
pinMode(BTN_PIN, INPUT_PULLUP);
pinMode(PiezoPin, OUTPUT);
SPI.begin();
mfrc522.PCD_Init();
lcd.clear(); //Use it to clear the LCD Widget
EEPROM.begin(512);
DisplayWAiT_CARD();
EEPROMreadUIDcard();
digitalWrite(PiezoPin, HIGH), delay(100), digitalWrite(PiezoPin, LOW);
if (digitalRead(BTN_PIN) == LOW) {
digitalWrite(SLN_PIN, HIGH); //unlock
lcd.clear();
lcd.print(0, 0, " Button Unlock");
lcd.print(0, 1, " Open ");
digitalWrite(PiezoPin, HIGH), delay(200), digitalWrite(PiezoPin, LOW);
delay(2000);
DisplayWAiT_CARD();
if (beginCard == 0) {
if ( ! mfrc522.PICC_IsNewCardPresent()) { //Look for new cards.
return;
if ( ! mfrc522.PICC_ReadCardSerial()) { //Select one of the cards.
return;
//Read "UID".
for (byte i = 0; i < mfrc522.uid.size; i++) {
uidDecTemp = mfrc522.uid.uidByte[i];
uidDec = uidDec * 256 + uidDecTemp;
if (beginCard == 1 || LockSwitch > 0)EEPROMwriteUIDcard(); //uidDec == adminID
if (LockSwitch == 0) {
//CardUIDeEPROMread.
for (ARRAYindexUIDcard = 0; ARRAYindexUIDcard <= 9; ARRAYindexUIDcard++) {
if (CardUIDeEPROMread[ARRAYindexUIDcard] > 0) {
if (CardUIDeEPROMread[ARRAYindexUIDcard] == uidDec) {
lcd.clear();
lcd.print(0, 0, " Door Open ");
lcd.print(3, 1, uidDec);
delay(2000);
break;
if (ARRAYindexUIDcard == 10) {
lcd.clear();
lcd.print(0, 0, " Card not Found ");
lcd.print(0, 1, " ");
lcd.print(0, 1, "ID : ");
lcd.print(5, 1, uidDec);
for (int i = 0; i <= 2; i++)delay(100), digitalWrite(PiezoPin, HIGH), delay(100), digitalWrite(PiezoPin, LOW);
digitalWrite(SLN_PIN, LOW); //lock();
delay(2000);
DisplayWAiT_CARD();
BLYNK_WRITE(V1) {
int a = param.asInt();
if (a == 1) beginCard = 1; else beginCard = 0;
BLYNK_WRITE(V2) {
if (a == 1) {
skipCard = 1;
if (EEPROMstartAddr / 5 < 10) EEPROMwriteUIDcard();
skipCard = 0;
BLYNK_WRITE(V3) {
if (a == 1) {
lcd.clear();
lcd.print(0, 0, " App Button ");
delay(2000);
DisplayWAiT_CARD();
void EEPROMwriteUIDcard() {
lcd.clear();
lcd.print(0, 0, " Add Card ");
lcd.print(0, 1, " Scan Card ");
delay(500);
if (LockSwitch > 0) {
if (skipCard == 1) { //uidDec == adminID
lcd.clear();
lcd.print(0, 0, " Remove Card ");
lcd.print(0, 1, " label : ");
lcd.print(11, 1, EEPROMstartAddr / 5);
EEPROMstartAddr += 5;
skipCard = 0;
Serial.println("writeCard");
EEPROM.write(EEPROMstartAddr, uidDec & 0xFF);
EEPROM.write(EEPROMstartAddr + 1, (uidDec & 0xFF00) >> 8);
EEPROM.write(EEPROMstartAddr + 2, (uidDec & 0xFF0000) >> 16);
EEPROM.write(EEPROMstartAddr + 3, (uidDec & 0xFF000000) >> 24);
EEPROM.commit();
lcd.clear();
lcd.print(0, 0, "Add Card ");
lcd.print(0, 1, "MEMORY : ");
lcd.print(9, 1, EEPROMstartAddr / 5);
delay(500);
LockSwitch++;
if (EEPROMstartAddr / 5 == 10) {
lcd.clear();
lcd.print(0, 0, "RECORD FINISH");
delay(2000);
EEPROMstartAddr = 0;
uidDec = 0;
void EEPROMreadUIDcard() {
for (int i = 0; i <= 9; i++) {
byte val = EEPROM.read(EEPROMstartAddr + 3);
CardUIDeEPROMread[ARRAYindexUIDcard] = (CardUIDeEPROMread[ARRAYindexUIDcard] << 8) | val;
val = EEPROM.read(EEPROMstartAddr + 2);
val = EEPROM.read(EEPROMstartAddr + 1);
val = EEPROM.read(EEPROMstartAddr);
ARRAYindexUIDcard++;
uidDec = 0;
LockSwitch = 0;
DisplayWAiT_CARD();
void DisplayWAiT_CARD() {
lcd.clear();
lcd.print(0, 0, " SCAN CARD");
