I’m unable to install blynklib on micropython ESP01 using Thonny
soft version esp8266-20230426-v1.20.0
What is the issue ?
Not sure what the problem is, but that’s the wrong library anyway (assuming that you’re wanting to use it with Blynk IoT).
Rather than keep repeating stuff that has been said before, I’d suggest that you read this topic from about here…
and make sure that you read down as far as post #14
something is wrong, i try to upload manualy to ESP01 but there is error I can’t even see the booy.py file on the list
can run it in shell
