Can't get the notifications
Hello everyone, i cant get the notifications on my phone. Everything is working clearly. If loops are okey and serial give me the message for them but i cant get the notifications. Any guess for the problem ?
Thanks for everyhting.
#include <DHT.h>
char auth[] = "--";
char ssid[] = "--";
char pass[] = "--";
#define DHTPIN 5          // Digital pin 2
#define DHTTYPE DHT11     // DHT 11
#define trig D3
#define echo D4
#define RelayPin1 12 // d6
#define fanPin1 13 // d7
#define RelayPin3 14 // d5
#define VPIN_BUTTON_1    V2
#define VPIN_BUTTON_2    V7
#define VPIN_BUTTON_3    V8
int toggleState_1 = 1;
int fanPinState1 = 1;
int toggleState_3 = 1;
int uyari2 = 0;
int uyari3=0;
int uyari1=0;
int uyari7 = 0;
int sensorpin=A0; // Soil Moisture çıkışı
int sensorvalue=0;
int outputvalue=0;
DHT dht(DHTPIN, DHTTYPE);
BLYNK_CONNECTED() {
  Blynk.syncVirtual(VPIN_BUTTON_1);
  Blynk.syncVirtual(VPIN_BUTTON_2);
  Blynk.syncVirtual(VPIN_BUTTON_3);
BLYNK_WRITE(VPIN_BUTTON_1) {
  toggleState_1 = param.asInt();
  digitalWrite(RelayPin1, toggleState_1);
BLYNK_WRITE(VPIN_BUTTON_2) {
  fanPinState1 = param.asInt();
  digitalWrite(fanPin1, fanPinState1);
BLYNK_WRITE(VPIN_BUTTON_3) {
  toggleState_3 = param.asInt();
  digitalWrite(RelayPin3, toggleState_3);
      Blynk.notify("ROW 1 HUMIDITY LEVEL 80%. VALVE CLOSING");
  pinMode(RelayPin1, OUTPUT); //Declare Pin mode
  pinMode(fanPin1, OUTPUT); //Declare Pin mode
  pinMode(RelayPin3, OUTPUT); //Declare Pin mode
  digitalWrite(RelayPin1, toggleState_3);
  dht.begin();
//  timer.setInterval(1000L, Wlevel);
  pinMode(trig, OUTPUT);
  pinMode(echo, INPUT);
 // timer.setInterval(1000L, sendSensor);
  delay(100);
  //timer.run();
  //soil için
  sensorvalue=analogRead(sensorpin);
  outputvalue=map(sensorvalue,620,310,0,100); //100,0 pottupaaru
 if(outputvalue > 100)
  outputvalue=100;
  Serial.println("100 %");
else if(outputvalue <=0)
    outputvalue=0;
  Serial.println("0 %");
}else if(outputvalue >0 && outputvalue < 100)
  Serial.print(outputvalue);
  Serial.println("%");
if(outputvalue >80){
    Serial.println("girdi");
    digitalWrite(RelayPin1, HIGH);
    Blynk.virtualWrite(V2, HIGH);
    toggleState_1 = 0;
    Serial.println("uyarı");
    uyari7=1;
  }else {
    if ( outputvalue <40){
    digitalWrite(RelayPin1, LOW);
    Blynk.virtualWrite(V2, LOW);
        toggleState_1 = 1;
  Blynk.virtualWrite(V4,outputvalue);
  float h = dht.readHumidity();
  float temperature = dht.readTemperature();
  if (isnan(h) || isnan(temperature)) {
    return;
  Blynk.virtualWrite(V5, h);  //V5 is for Humidity
  Blynk.virtualWrite(V6, temperature);  //V6 is for Temperature
    if(temperature >= 25 && uyari2 == 0){
      Serial.println("fan için girdi");
    digitalWrite(fanPin1, LOW);
     Blynk.virtualWrite(V7,255);
    fanPinState1 = 0;
    Blynk.notify("High Temperature.Fan Startıng");
    uyari2=1;
  }else {
    if ( temperature <25){
    uyari2 = 0;
  if (temperature < 25  && uyari1 == 0){
     digitalWrite(fanPin1, HIGH);
    Blynk.virtualWrite(V7,0);
    Blynk.notify("Low Temperature,Fan Stoping ");
        uyari1=1;
     Serial.println("fan için çıktı");
        }else {
    if ( temperature > 25 ){
    uyari1 = 0;
  digitalWrite(trig, LOW);
  delayMicroseconds(4);
  digitalWrite(trig, HIGH);
  delayMicroseconds(10);
  long t = pulseIn(echo, HIGH);
  long cm = t / 29 / 2;
  Blynk.virtualWrite(V1, cm);
  Serial.println(cm);
  if(cm <= 10 && uyari3 == 0){
    digitalWrite(RelayPin3, HIGH);
    Blynk.virtualWrite(V8,0);
    Blynk.notify("Water Tank Level %70.Water Valve Closing.");
    uyari3=1;
  }else {
    if ( cm > 11 ){
    uyari3 = 0;
    Blynk.virtualWrite(V8,255);
    digitalWrite(RelayPin3, LOW);
