in blynk platform temperature and humudity was not able to show the live data rest can show the data
and its keep tells cannot get the sensor value
here is my code assist me with this
/* Connections
Relay. D3
Btn. D7
Soil. A0
PIR. D5
SDA. D2
SCL. D1
Temp. D4
//Include the library files
#include <DHT.h>
//Initialize the LCD display
LiquidCrystal_I2C lcd(0x3F, 16, 2);
char auth[] = "WVSuOSp7V4cZqnZ9BAvwx65VTl-RnKEJ"; //Enter your Blynk Auth token
char ssid[] = "D-Link-vimal"; //Enter your WIFI SSID
char pass[] = "ypkrex8dxx"; //Enter your WIFI Password
DHT dht(D4, DHT11);//(DHT sensor pin,sensor type) D4 DHT11 Temperature Sensor
//Define component pins
#define soil A0 //A0 Soil Moisture Sensor
#define PIR D5 //D5 PIR Motion Sensor
int PIR_ToggleValue;
void checkPhysicalButton();
int relay1State = LOW;
int pushButton1State = HIGH;
#define RELAY_PIN_1 D3 //D3 Relay
#define PUSH_BUTTON_1 D7 //D7 Button
#define VPIN_BUTTON_1 V12
//Create three variables for pressure
double T, P;
char status;
lcd.init();
lcd.backlight();
pinMode(PIR, INPUT);
pinMode(RELAY_PIN_1, OUTPUT);
digitalWrite(RELAY_PIN_1, LOW);
pinMode(PUSH_BUTTON_1, INPUT_PULLUP);
digitalWrite(RELAY_PIN_1, relay1State);
Blynk.begin(auth, ssid, pass, "blynk.cloud", 80);
dht.begin();
lcd.setCursor(0, 0);
lcd.print(" Initializing ");
for (int a = 5; a <= 10; a++)
lcd.setCursor(a, 1);
lcd.print(".");
delay(500);
lcd.clear();
lcd.setCursor(11, 1);
lcd.print("W:OFF");
//Call the function
timer.setInterval(100L, soilMoistureSensor);
timer.setInterval(100L, DHT11sensor);
timer.setInterval(500L, checkPhysicalButton);
//Get the DHT11 sensor values
void DHT11sensor() {
float h = dht.readHumidity();
if (isnan(h) || isnan(t)) {
return;
Blynk.virtualWrite(V0, t);
Blynk.virtualWrite(V1, h);
lcd.print("T:");
lcd.print(t);
lcd.setCursor(8, 0);
lcd.print("H:");
lcd.print(h);
//Get the soil moisture values
void soilMoistureSensor() {
int value = analogRead(soil);
value = map(value, 0, 1024, 0, 100);
value = (value - 100) * -1;
Blynk.virtualWrite(V3, value);
lcd.setCursor(0, 1);
lcd.print("S:");
lcd.print(value);
lcd.print(" ");
//Get the PIR sensor values
void PIRsensor() {
bool value = digitalRead(PIR);
if (value) {
Blynk.logEvent("Motion dedection","WARNNG! Motion Detected!"); //Enter your Event Name
WidgetLED LED(V5);
LED.on();
WidgetLED LED(V5);
LED.off();
BLYNK_WRITE(V6)
PIR_ToggleValue = param.asInt();
BLYNK_CONNECTED() {
Blynk.syncVirtual(VPIN_BUTTON_1);
BLYNK_WRITE(VPIN_BUTTON_1) {
relay1State = param.asInt();
if (digitalRead(PUSH_BUTTON_1) == LOW) {
// pushButton1State is used to avoid sequential toggles
if (pushButton1State != LOW) {
// Toggle Relay state
relay1State = !relay1State;
// Update Button Widget
Blynk.virtualWrite(VPIN_BUTTON_1, relay1State);
pushButton1State = LOW;
if (PIR_ToggleValue == 1)
lcd.setCursor(5, 1);
lcd.print("M:ON ");
PIRsensor();
lcd.print("M:OFF");
WidgetLED LED(V5);
LED.off();
if (relay1State == HIGH)
lcd.print("W:ON ");
else if (relay1State == LOW)
lcd.print("W:OFF");
Blynk.run();//Run the Blynk library
timer.run();//Run the Blynk timer
