Can't get Gps stream location
Hi all…i am creating project in which i am using blynk Gps stream widget to get my mobile location on Wemos d1 board when i press 1 on serial monitor… but it kinda not work the way i want…my longitude and lattitude variables always stays zero…i have provided the code below(i know my coding style is way bad and i am trying to improve…yes i am student :slight_smile: …and newbie here)…and sorry if my english is bad too…
#define BLYNK_MAX_SENDBYTES 200
char auth[] = "put your own";
char userEmail[] = "put your own";
char ssid[] = "put your own";
char pass[] = "put your own";
float latitude = 0.00;
float longitude= 0.00;
double altitude;
double speed;
byte input_char=0;
long user_input=0;
bool proDebug = 1; // TODO - set to 0 if not debugging
int i=0;
int online;
BLYNK_WRITE(V0) // read virtual pin 0 for co-ordinates
  latitude = param[0].asDouble();
  longitude = param[1].asDouble();
  altitude = param[2].asDouble();
  speed = param[3].asDouble();
void getLocation()
  if(i == 9)
      Serial.println("Device unreachable");
      i=0;
      online = 0;
  if(i == 0)
       Serial.println();
       Serial.println("press 1 to get phone Location:");
       Serial.println();
      while(Serial.available() == 0) {Blynk.run();}
      while(Serial.available())
          input_char = Serial.read() - 48;
           user_input = user_input * 10 + input_char;
      if(user_input == 1)
        online = 1;
        Serial.println("wrong entry.");
        Serial.println();
    if(online == 1)
      if(latitude != 0.00 && longitude != 0.00) // if co-ordinates are valid
        //String toSend is the string that will be sent as the emails body
        String toSend = "Phone Located! \n received co-ordinates \n LAT ";
        toSend += String(latitude, 8);
        toSend += " LNG ";
        toSend += String(longitude, 8);
        toSend += ". View location on: ";
        toSend += "www.google.com/maps/?q=";
        toSend += ",";
        delay(500);
        if(proDebug)
          Serial.println("Phone geolocation found");
          Serial.println("Sending Email...");
          Serial.println(toSend);
        Blynk.email(userEmail, "PhoneLocator | Notification", toSend); // send email
        if(proDebug)
          Serial.println("Success");
          Serial.println("Email Sent");
          Serial.println("Restarting Protocol");
          Serial.println("");
        delay(500);
        i=0;
        online = 0;
        latitude = 0.00;
        longitude= 0.00;
          if(i==0 || i == 8)
                Serial.println("Geolocation not Received");
                Serial.println("server responded with");
                Serial.println(latitude, 8);
                Serial.println(longitude, 8);
                Serial.println("");
                Serial.println("checking again.");
                Serial.println("");
            i++;
    //while end
input_char=0;
user_input=0;
  if(proDebug)
    while(!Serial) {};
    Serial.println("Tracker is online");
    Serial.println("");
    delay(500);
  getLocation();
This delay is totally unnecessary.
First you declare them as Float, then process them as Double… Try using float for everything.
Or take a look at the GPS Streaming example
thanks for reply. :slight_smile:
so for double check i followed that example sketch …and found that
BLYNK_WRITE(V0)
is not running because my serial monitor stays blank after its connected with blynk server…
code:
char auth[] = "";
char ssid[] = "";
char pass[] = "";
BLYNK_WRITE(V0) {
 GpsParam gps(param);
 // Print 6 decimal places for Lat, Lon
 Serial.print("Lat: ");
 Serial.println(gps.getLat(), 7);
 Serial.print("Lon: ");
 Serial.println(gps.getLon(), 7);
 // Print 2 decimal places for Alt, Speed
 Serial.print("Altitute: ");
 Serial.println(gps.getAltitude(), 2);
 Serial.print("Speed: ");
 Serial.println(gps.getSpeed(), 2);
 Serial.println();
ok i just found there is no error in code(realy sorry for taking ur time)…its just my internet but…its still a problem for me cuz i wont be having my home wifi in college.
Actually when i use my home internet…every thing works fine…but when i use my mobile data and hotspot(for wemos d1)…i get no reponse from VirtualWrite function. but its says i am connected to blynk server…
i tried mine and my dads mobile data…both doesn’t work.
It sounds like your mobile provider(s) are blocking some people f communication protocols needed for device to server to device communication.
