I want to rearrange my code to become object oriented so I can reuse to my another project. I am using raspberry pi and this machine recommend me to use python. I am not an python expert because I think this question more like python question rather than blynk question.
import blynklib
class blynk_input(Base):
pass
auth_token= 'my token was here...'
blynk = blynklib.Blynk(auth_token)
input_throttle = 0
input_yaw = 0
input_roll = 0
input_pitch = 0
@blynk.handle_event("connect")
def connect_handler():
for pin in range(4):
print('Syncing virtual pin {}'.format(pin))
blynk.virtual_sync(pin)
# within connect handler after each server send operation forced socket reading is required cause:
# - we are not in script listening state yet
# - without forced reading some portion of blynk server messages can be not delivered to HW
blynk.read_response(timeout=0.3)
so I made a class called blynk_input and whatever written here is to communicate with blynk data.
and then I made a subclass of this to handle specific algorithm in my project:
from blynk_aeromodel import blynk_input
class elevon(blynk_input):
pass
#raspberry pi hardware pwm only has 2 channel,
#gpio bcm 13 and gpio bcm 19 is in same channel
#gpio bcm 12 and gpio bcm 18 is in same channel
rudderPin = 27 #software
throttlePin = 22 #software
elevonLPin = 18 #hardware
elevonRPin = 13 #hardware
#initiation purpose
input_elevonL = 0
input_elevonR = 0
hw_midValue = 0.0
sw_midValue = 0.0
input_elevonTrigger = False
def run(self):
print("make sure daemon pigpiod already running (sudo pigpiod)")
print("rudder pin: " +str(self.rudderPin))
try:
#software pwm
self.init_SW_PWM("Throttle software pwm", self.throttlePin, 50, self.setSWAngletoPWM(90))
self.init_SW_PWM("Rudder software pwm", self.rudderPin, 50, self.setSWAngletoPWM(90))
#hardware pwm
self.init_HW_PWM("Elevon L hardware pwm", self.elevonLPin, 50, self.setHWAngletoPWM(90))
self.init_HW_PWM("Elevon R hardware pwm", self.elevonRPin, 50, self.setHWAngletoPWM(90))
#set mid value point to 90
#untuk kalibrasi algoritma elevon
self.hw_midValue = self.setHWAngletoPWM(90)
self.sw_midValue = self.setSWAngletoPWM(90)
while True:
self.blynk.run()
print("roll :"+ str(input_roll))
finally:
self.gpio.stop()
as written above, I able to call member blynk in blynk_input class by call self.blynk.run()
and then I just instantiate in my main class:
from elevon_model import elevon
class main_aero(Daemon):
def run(self):
# this is only snip code
aero = elevon()
aero.run()
it’s running.
however, I got an error once I give an internet connection. this is error message:
self._events[event](*args, **kwargs)
File "/home/pi/python_script/aeromodel/blynk_aeromodel.py", line 17, in connect_handler
NameError: global name 'blynk' is not defined
blynk will trigger @blynk.handle_event("connect") however I can’t refer my instance which is usually defined in parameter as self. I don’t know how blynk decorator working but looks like it’s running outside of my instance. this is another error if I added self manually on handler:
self.call_handler(self._CONNECT)
File "/usr/local/lib/python2.7/dist-packages/blynklib.py", line 343, in call_handler
TypeError: connect_handler() takes exactly 1 argument (0 given)
