Sketch builder does not specifically support FONA 800 but it is in the list of supported products. Anyway, I selected the SimCom SIM800 and get:
[13310] Modem init…
[23539] Cannot init
I’m using a hologram sim card.
[13310] Modem init…
[23539] Cannot init
That means the modem is simply “invisible” to Arduino. Bad serial connection, wrong serial port settings?? Error in code? Who knows? Too little information provided.
At a bit of a loss as to what other info I might provide I remembered something way back about incorrect pins for the software serial so, in desperation swapped them:
SoftwareSerial SerialAT(3, 2);
and got this, with about a 10 min gap after “[23989] Connecting to hologram …”
[13116] Modem init…
[16461] Connecting to network…
[23989] Network: Rogers Wh�eless
[201782] Connect GPRS failed
Initializing modem…
[16408]
___ __ __
/ _ )/ /_ _____ / /__
/ _ / / // / _ / '/
///_, /////_
/__/ v0.6.1 on Arduino Uno
[16501] Modem init…
[23846] SIM is missing
Initializing modem…
Perhaps SoftwareSerial is set incorrectly (speed?). But because of your “TOP SECRET” code, that is all I can help you.
This bit of code is from the Adafruit Fona 800 test example:
#define FONA_RX 2
#define FONA_TX 3
l…
SoftwareSerial fonaSS = SoftwareSerial(FONA_TX, FONA_RX);
Now, I did generate the example for the SimCOM SIM800 (the FONA 800 is not in the list) and the generated code would be correct. However the FONA is quite popular and a comment in the generated code might save some confusion.
Thanks very much for the support and if I can’t get this working today I’ll buy a SIM800. Cheers.
Perhaps this should be your start point: https://github.com/vshymanskyy/TinyGSM#softwareserial-problems
Generated code:
SerialAT.begin(115200);
Changed to 9600 and connects fine. A comments please.
So You wasted some significant amount of time just because you were keeping it secret… Up until now. That is my comment.
My apologies for confusion.
The code generated by the example builder for the Arduino and SimCOM SIM800 contains:
SoftwareSerial SerialAT(2, 3); // RX, TX
To work with the Adafruit FONA 800 these lines need to be changed to:
SoftwareSerial SerialAT(3, 2); // RX, TX
SerialAT.begin(9600);
It would help if the code generated included a comment with these changes for those trying to get the FONA working.
FYI SoftSerial on Atmega (Arduino) works quite stable up to about 33600 bps
