Cant get any data from my sensor
Arduino UNO with ESP8266
On Android
Im trying to get data from the sensor to read at virtual pin on my blnyk app
Try to study this alone… Just cant get my head wrap around it
    Follow us:                  http://www.fb.com/blynkapp
                                http://twitter.com/blynk_app
  WARNING!
    It's very tricky to get it working. Please read this article:
    http://help.blynk.cc/hardware-and-libraries/arduino/esp8266-with-at-firmware
  Output any data on LCD widget!
  App project setup:
    LCD widget, SIMPLE mode, in widget settings :
    - Select pin V0 for zero pin
    - Select pin V1 for first pin
    - Change "Reading Frequency" to PUSH mode
    - Type into first edit field "/pin0/ seconds"
    - Type into second edit field "/pin1/ millis"
#include <ESP8266_Lib.h>
#include <Wire.h>
#define SensorPin A0            //pH meter Analog output to Arduino Analog Input 0
#define Offset 0.00            //deviation compensate
#define LED 13
#define samplingInterval 20
#define printInterval 800
#define ArrayLenth  40    //times of collection
char auth[] = "7478f757cb7a4456889a987d2b4ff8e8";
char ssid[] = "MaroiFunFun@unifi";
char pass[] = "hud4shr@ff";
#define EspSerial Serial1
// Your ESP8266 baud rate:
#define ESP8266_BAUD 9600
ESP8266 wifi(&EspSerial);
int pHArray[ArrayLenth];   //Store the average value of the sensor feedback
int pHArrayIndex=0;
void sendSeconds() {
  Blynk.virtualWrite(V0, millis() / 1000);
void sendMillis() {
  Blynk.virtualWrite(V1, millis());
  // Set ESP8266 baud rate
  //Blynk.begin(auth, wifi, ssid, pass, "blynk-cloud.com", 80);
  //Blynk.begin(auth, wifi, ssid, pass, IPAddress(192,168,1,100), 8080);
  timer.setInterval(1000L, sendSeconds);
  timer.setInterval(1000L, sendMillis);
void myTimerEvent()
  static unsigned long samplingTime = millis();
  static unsigned long printTime = millis();
  static float pHValue,voltage;
  if(millis()-samplingTime > samplingInterval)
      pHArray[pHArrayIndex++]=analogRead(A0);
      if(pHArrayIndex==ArrayLenth)pHArrayIndex=0;
      voltage = avergearray(pHArray, ArrayLenth)*5.0/1024;
      pHValue = 4.0*voltage+Offset;
      samplingTime=millis();
  Blynk.virtualWrite(V3, pHValue); //sending to Blynk
double avergearray(int* arr, int number){
  int i;
  int max,min;
  double avg;
  long amount=0;
  if(number<=0){
    Serial.println("Error number for the array to avraging!/n");
    return 0;
  if(number<5){   //less than 5, calculated directly statistics
    for(i=0;i<number;i++){
      amount+=arr[i];
    avg = amount/number;
    return avg;
  }else{
    if(arr[0]<arr[1]){
      min = arr[0];max=arr[1];
    else{
      min=arr[1];max=arr[0];
    for(i=2;i<number;i++){
      if(arr[i]<min){
        amount+=min;        //arr<min
        min=arr[i];
      }else {
        if(arr[i]>max){
          amount+=max;    //arr>max
          max=arr[i];
        }else{
          amount+=arr[i]; //min<=arr<=max
      }//if
    }//for
    avg = (double)amount/(number-2);
  }//if
  return avg;
Where are the functions you call? (sendSeconds and sendMillis)
In addition to that, your have 2 timers at the same time , not possible unless you use ESP32 !
and where is the timer calling your myTimerEvent () function ?
Thank you for replying.
I’m a student, still learning, a very beginner programmer. I don’t understand your question. i simply copy from the blynk example builder and then transfer my calculation of the sensor to the example code.
Can you explain more?
sorry I missed
void sendMillis() {
but you need to stage timers and add a timer to call myTimerEvent ()
Okay. i have added code below but still no data
did you add this to the setup?
What type of display/widget do you have attached to V3? is the reading rate of this widget set to push? Do you need to check the pH every second?
Yes i added the code to setup.
I used the value display widget. Yes, i set it to push. Every 1 seconds.
Can you help me?
Is the device actually connecting to BLYNK?
Is the project running?
Try adding some serial prints to your function to see if the sensor is actually producing data.
You don’t need this. The timer takes care of this for you.
You have 3 timers at 1000L !
Yes connected. I set a LED on pin digital it can switch on. Maybe something wrong in myTimerEvent().
I already remove it but still no data. :frowning:
What should i put instead sir?
Maybe like this?
void myTimerEvent()
           pHArrayIndex=0;
and then decrease your timer interval to like .1 seconds
timer.setInterval(100L, myTimerEvent);
so 40 total samples, with each sample taken every .1 seconds, you should get an averaged reading every 4 seconds??
Waaaa. Thank you very much. That pretty much done it. :smile:
Sir,
Can you help me with one more thing. I seem cannot to display data on my LCD. When i run the coding without the blynk connection, the lcd seem to be working.
  WARNING!
  App project setup:
#include <Wire.h>
#define LED 13
LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);
int pHArrayIndex=0;
void sendMillis() {
  lcd.begin(16,2);
void myTimerEvent()
           pHArrayIndex=0;
    lcd.clear();
    lcd.setCursor(0,1);
    lcd.print("pH      = ");
    lcd.print(pHValue);
  int i;
  int max,min;
  double avg;
  long amount=0;
  if(number<=0){
    return 0;
      amount+=arr[i];
    return avg;
  }else{
    if(arr[0]<arr[1]){
    else{
      if(arr[i]<min){
        min=arr[i];
      }else {
        if(arr[i]>max){
          max=arr[i];
        }else{
      }//if
    }//for
  }//if
  return avg;
what pins is the LCD connected to?
try putting it inside the second if statement.
void myTimerEvent()
           pHArrayIndex=0;
              lcd.clear();
             lcd.setCursor(0,1);
              lcd.print("pH      = ");
               lcd.print(pHValue);
Still no display. Other data also not displaying.
The lcd connected to the sda and the scl pins.
