Can’t delete the first project that I converted to an app, but even after deleting the app I still can’t see the nut icon and hence no delete option.
I am not a heavy user of Faces or App preview, so can’t easily give you the steps, but I believe you first need to delete the Face project, then the App project.
@Gunner is right, if you had created an app for your project, it would be impossible to remove the project and it’s devices. You need to remove the app first.
I believe there is some glitch in the software because I deleted the app(every app actually) as you can see the second screenshot above. One more thing is that if I create an app for some other project, it works the same as you guys suggested but not for the first project
That will be fixed in the next app’s release. I’ve had luck to reproduce such issues.
