So my team tried to connect arduino MEGA 2560 + ESP-01
we flash the necessary AT firmwares, download the latest blynk libraries but could not make the ESP 01 connect to the blynk server. There are times that it connects, but the connection will drop after 20 to 30 seconds.! Here’s my serial monitor after uploading the code to the MEGA board
[9]
___ __ __
/ _ )/ /_ _____ / /__
/ _ / / // / _ \/ '_/
/____/_/\_, /_//_/_/\_\
/___/ v0.5.1 on Arduino Mega
[592] Connecting to PLDTHOMEDSLPAKABITKADIN
[3642] AT version:1.1.0.0(May 11 2016 18:09:56)
SDK version:1.5.4(baaeaebb)
Ai-Thinker Technology Co. Ltd.
Jun 13 2016 11:29:20
OK
[10771] +CIFSR:STAIP,"192.168.1.10"
+CIFSR:STAMAC,"60:01:94:4c:94:d4"
[10779] Connected to WiFi
[21219] Redirecting to 45.55.96.146:8080
And the nothing happens.
any suggestions on what might be the problem?
here’s my code
#include <ESP8266_Lib.h>
#include <DHT.h>
char auth[] = "MYAUTHTOKEN";
char ssid[] = "MYSSID";
char pass[] = "MYPASSWORD";
#define EspSerial Serial1
//#include <SoftwareSerial.h>
// Your ESP8266 baud rate:
#define ESP8266_BAUD 115200
ESP8266 wifi(&EspSerial);
#define DHTPIN 22 // What digital pin we're connected to
#define DHTTYPE DHT22 // DHT 11
//#define DHTTYPE DHT22 // DHT 22, AM2302, AM2321
//#define DHTTYPE DHT21 // DHT 21, AM2301
DHT dht(DHTPIN, DHTTYPE);
void myTimerevent ()
Blynk.virtualWrite(V7, millis() / 1000);
void sendSensor()
float h = dht.readHumidity();
if (isnan(h) || isnan(t)) {
return;
Blynk.virtualWrite(V5, h);
Blynk.virtualWrite(V6, t);
// Set ESP8266 baud rate
Blynk.begin(auth,wifi, ssid, pass);
// Blynk.begin(auth, wifi, ssid, pass, "blynk-cloud.com", 8442);
//Blynk.begin(auth, wifi, ssid, pass, IPAddress(192,168,1,100), 8442);
dht.begin();
timer.setInterval(1000L, myTimerevent);
