In this screenshot, it is 2.3.0
Look under board manager in the Arduino IDE.
https://iotguider.in/wp-content/uploads/2017/08/ESP8266-in-Arduino-Boards-Manager.pngIn this screenshot, it is 2.3.0
https://iotguider.in/wp-content/uploads/2017/08/ESP8266-in-Arduino-Boards-Manager.pngOk Pete, that’s what I thought we had to do and that matches my ohmic readings. Thanks.
Arduino IDE 1.8.9 beta
ConnectThings_ESP8266 version 0.0.1
Blynk version 0.6.1
@zener In Arduino IDE choose:
Tools/Board/Boards Manager.
Scroll down towards the bottom of the list and find “esp8266 by ESP8266 Community” and tell us what version you have installed.
If it’s anything higher than 2.4.2, downgrade to 2.4.2 and recompile/upload your code and tell us what happens.
Have you tried to open port 80 of your router?
Looks like you are connecting to your router via WiFi OK, but not actually getting traffic out to the internet.
Edit: Also maybe just try to reset your router? (Off, back on again - not settings
If it’s ok with d1 mini (not pro) board, it means no problem with port 80 i presume ?
Oh un Français
Ah, yes of course - silly me
No, thanks for looking for a solution to my problem
Try to set a Fix IP 192.168.1.48, same as D1 mini
and a other one i presume
OUI , en effet !!!
I’ve just uploaded your code onto a brand new D1 Mini Pro and it works fine for me:
[67] Connecting to xxxxxxxxxxx
[569] Connected to WiFi
[569] IP: 192.168.1.59
[569]
___ __ __
/ _ )/ /_ _____ / /__
/ _ / / // / _ \/ '_/
/____/_/\_, /_//_/_/\_\
/___/ v0.6.1 on ESP8266
[641] Connecting to blynk-cloud.com:80
[827] Ready (ping: 43ms).
This is with nothing at all connected to the board, other than the USB power/data cable.
The only difference seems to be that I’m running Arduino IDE 1.8.9 (not the beta version).
What happens if you choose your board type as a D1 Mini (not Pro) or NodeMCU?
Also, try turning on verbose messages (File/Preferences/Show verbose output during - select Compilation & Output). Do you get any warnings, or messages about duplicate libraries?
I get the following towards the end of the compilation, and it works okay:
Unable to cache built core, please tell esp8266 maintainers to follow http://goo.gl/QdCUjo
Check that you have two lines that look similar to this and that the file versions are the same:
Using library ESP8266WiFi at version 1.0 in folder: C:\Users\Pete Knight\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.2\libraries\ESP8266WiFi
Using library Blynk at version 0.6.1 in folder: C:\Users\Pete Knight\Documents\Arduino\libraries\Blynk
I forced ip 192.168.1.48 for my d1 mini pro and I connected to the blynk server !!
And on my phone, my blynk app confirms it!
Thank you all for your help - excellent support ![]()
Of course the best would be to understand why it works with this ip !
Any idea ?
your livebox is silly
check the DHCP range
