Ok I will try adding gpio 2 in #define BOARD_LED_PIN
What about for?
#define BOARD_BUTTON_PIN
What gpio pin should I add?
What about for?
Yes you will need that I am looking to see if I can find that pin number
I only managed to find two other threads.
I tried the solution from one of the thread which is to disable debug (#define APP_DEBUG) but it doesn’t work for me
The other thread somehow doesn’t show any solution.
the BOOT button is connected to GPIO0 so pressing it will pull GPIO0 low.
#define BOARD_BUTTON_PIN 0
I think this would work in settings.h
#define BOARD_BUTTON_PIN 0 // Pin where user button is attached
#define BOARD_BUTTON_ACTIVE_LOW true // true if button is "active-low"
#define BOARD_LED_PIN 2 // Set LED pin - if you have a single-color LED attached
//#define BOARD_LED_PIN_R 15 // Set R,G,B pins - if your LED is PWM RGB
//#define BOARD_LED_PIN_G 12
//#define BOARD_LED_PIN_B 13
//#define BOARD_LED_PIN_WS2812 4 // Set if your LED is WS2812 RGB
#define BOARD_LED_INVERSE false // true if LED is common anode, false if common cathode
#define BOARD_LED_BRIGHTNESS 64 // 0..255 brightness control
once you get that done press and hold the boot button for 10 seconds
@yowckie you need to edit the custom board configuration to suit your board, as described here:
