I am having trouble connecting my nodemcu board to blynk application. I am using android OS. If I click the add new device, then find devices nearby, there’s a message there that says,
Make sure your device is ready to be connected
Make sure that your device and smartphone are very close to the router
If your device's LED is not blinking check device's manual on how to do a reset. If a problem persists, contact our support team.
I did these things except my Nodemcu’s LED is not blinking, it only blinks when I click the RST button. What seems to be the problem?? Thank you
Which example sketch are you using?
If it’s the Edgent example, what board type have you un-commented in the sketch?
Have you created a template, and added the template ID and device name at the top of your sketch?
What does your serial monitor show?
When you post code or serial output text to the forum add triple backticks at the beginning and end of your code so that it displays correctly.
So just to clarify, you do have your actual template ID and device name in here in the actual sketch, copied and pasted from the template screen in the web console? (It’s best to replace these with the word “REDACTED” so that we know you’ve actually added values in there and then removed them for privacy purposes).
Have you mad any changes to the Settings.h tab, or any other .h tabs in the sketch?
What version of the ESP8266 core do you have installed?
Have you tried uploading with the “Erase Flash” option set to “All Flash Contents” ?
Yes, I removed the template ID and device name for privacy purposes.
I made some changes to the other h tabs because I only copied this code from browser. But in his code he included the manual control switch, so I removed it. This is the code of the BlynkEdgent h tab
extern "C" {
#include "user_interface.h"
void app_loop();
#include "Settings.h"
#include <BlynkSimpleEsp8266_SSL.h>
#ifndef BLYNK_NEW_LIBRARY
#error "Old version of Blynk library is in use. Please replace it with the new one."
#endif
#if !defined(BLYNK_TEMPLATE_ID) || !defined(BLYNK_DEVICE_NAME)
#error "Please specify your BLYNK_TEMPLATE_ID and BLYNK_DEVICE_NAME"
#endif
#include "BlynkState.h"
#include "ConfigStore.h"
#include "ResetButton.h"
#include "ConfigMode.h"
#include "Indicator.h"
#include "OTA.h"
#include "Console.h"
//void manual_control();
inline
void BlynkState::set(State m) {
if (state != m && m < MODE_MAX_VALUE) {
DEBUG_PRINT(String(StateStr[state]) + " => " + StateStr[m]);
state = m;
// You can put your state handling here,
// i.e. implement custom indication
void printDeviceBanner()
Blynk.printBanner();
DEBUG_PRINT("--------------------------");
DEBUG_PRINT(String("Product: ") + BLYNK_DEVICE_NAME);
DEBUG_PRINT(String("Firmware: ") + BLYNK_FIRMWARE_VERSION " (build " __DATE__ " " __TIME__ ")");
if (configStore.getFlag(CONFIG_FLAG_VALID)) {
DEBUG_PRINT(String("Token: ...") + (configStore.cloudToken+28));
DEBUG_PRINT(String("Device: ") + BLYNK_INFO_DEVICE + " @ " + ESP.getCpuFreqMHz() + "MHz");
DEBUG_PRINT(String("MAC: ") + WiFi.macAddress());
DEBUG_PRINT(String("Flash: ") + ESP.getFlashChipRealSize() / 1024 + "K");
String coreVer = ESP.getCoreVersion();
coreVer.replace("_", ".");
DEBUG_PRINT(String("ESP core: ") + coreVer);
DEBUG_PRINT(String("ESP SDK: ") + ESP.getSdkVersion());
DEBUG_PRINT(String("Boot Ver: ") + ESP.getBootVersion());
DEBUG_PRINT(String("Boot Mode:") + ESP.getBootMode());
DEBUG_PRINT(String("FW info: ") + ESP.getSketchSize() + "/" + ESP.getFreeSketchSpace() + ", MD5:" + ESP.getSketchMD5());
DEBUG_PRINT(String("Free mem: ") + ESP.getFreeHeap());
void runBlynkWithChecks() {
if (BlynkState::get() == MODE_RUNNING) {
if (!Blynk.connected()) {
if (WiFi.status() == WL_CONNECTED) {
BlynkState::set(MODE_CONNECTING_CLOUD);
BlynkState::set(MODE_CONNECTING_NET);
class Edgent {
public:
void begin()
indicator_init();
button_init();
config_init();
console_init();
printDeviceBanner();
} else if (config_load_blnkopt()) {
DEBUG_PRINT("Firmware is preprovisioned");
BlynkState::set(MODE_WAIT_CONFIG);
void run() {
app_loop();
switch (BlynkState::get()) {
case MODE_WAIT_CONFIG:
case MODE_CONFIGURING: enterConfigMode(); break;
case MODE_CONNECTING_NET: enterConnectNet(); break;
case MODE_CONNECTING_CLOUD: enterConnectCloud(); break;
case MODE_RUNNING: runBlynkWithChecks(); break;
case MODE_OTA_UPGRADE: enterOTA(); break;
case MODE_SWITCH_TO_STA: enterSwitchToSTA(); break;
case MODE_RESET_CONFIG: enterResetConfig(); break;
default: enterError(); break;
Edgent BlynkEdgent;
BlynkTimer edgentTimer;
void app_loop() {
edgentTimer.run();
edgentConsole.run();
//manual_control();
if (digitalRead(SwitchPin1) == LOW) {
digitalWrite(RelayPin1, toggleState_1);
toggleState_1 = !toggleState_1;
Blynk.virtualWrite(VPIN_BUTTON_1, toggleState_1);
delay(300);
if (digitalRead(SwitchPin2) == LOW) {
digitalWrite(RelayPin2, toggleState_2);
toggleState_2 = !toggleState_2;
Blynk.virtualWrite(VPIN_BUTTON_2, toggleState_2);
delay(300);
if (digitalRead(SwitchPin3) == LOW) {
digitalWrite(RelayPin3, toggleState_3);
toggleState_3 = !toggleState_3;
Blynk.virtualWrite(VPIN_BUTTON_3, toggleState_3);
delay(300);
if (digitalRead(SwitchPin4) == LOW) {
digitalWrite(RelayPin4, toggleState_4);
toggleState_4 = !toggleState_4;
Blynk.virtualWrite(VPIN_BUTTON_4, toggleState_4);
delay(300);
I’d suggest that you go to File > Examples > Blynk > Blynk.Edgent > Edgent ESP8266 which will pen a pristine Edgent sketch. Copy/Paste the two lines of Template ID etc from the template screen in the web browser, and paste them over the tow lines that are commented-out at the beginning of the sketch.
Uncomment the #define USE_NODE_MCU_BOARD line of code then save the sketch.
Go to Tools and “Erase Flash” option and set it set to “All Flash Contents”.
Upload the sketchy and check taht your LED flashes rapildly to indicate that it’s in provisioning mode. The serial monitor will also show this.
Provision the device via “+ Add Device” and ensure that it connects to Blynk.
You can then make the changes to the .ino file (leave all the others unchanged) and re-upload the sketch. There is no need to re-provision the device when you do this.
