Details :
• NodeMCU v1.0
• Color OS v11.1
• Blynk Library v1.0.1
Example code
#define BLYNK_TEMPLATE_ID "YourTemplateID"
char pass[] = "YourPassword";
Error Message:
Arduino: 1.8.19 (Windows Store 1.8.57.0) (Windows 10), Board: "NodeMCU 1.0 (ESP-12E Module), 80 MHz, Flash, Disabled (new aborts on oom), Disabled, All SSL ciphers (most compatible), 32KB cache + 32KB IRAM (balanced), Use pgm_read macros for IRAM/PROGMEM, 4MB (FS:2MB OTA:~1019KB), 2, v2 Lower Memory, Disabled, None, Only Sketch, 115200"
In file included from C:\Users\Matte\Documents\Arduino\libraries\Blynk\src/BlynkWidgets.h:14,
from C:\Users\Matte\Documents\Arduino\libraries\Blynk\src/BlynkSimpleEsp8266.h:103,
from C:\Users\Matte\AppData\Local\Temp\arduino_modified_sketch_488555\NodeMCU.ino:6:
C:\Users\Matte\Documents\Arduino\libraries\Blynk\src/WidgetTimeInput.h: In constructor 'TimeInputParam::TimeInputParam(const BlynkParam&)':
C:\Users\Matte\Documents\Arduino\libraries\Blynk\src/WidgetTimeInput.h:45:43: warning: implicitly-declared 'constexpr BlynkTime& BlynkTime::operator=(const BlynkTime&)' is deprecated [-Wdeprecated-copy]
45 | mStart = BlynkTime(it.asLong());
In file included from C:\Users\Matte\Documents\Arduino\libraries\Blynk\src/WidgetTimeInput.h:15,
C:\Users\Matte\Documents\Arduino\libraries\Blynk\src/utility/BlynkDateTime.h:40:5: note: because 'BlynkTime' has user-provided 'BlynkTime::BlynkTime(const BlynkTime&)'
40 | BlynkTime(const BlynkTime& t) : mTime(t.mTime) {}
C:\Users\Matte\Documents\Arduino\libraries\Blynk\src/WidgetTimeInput.h:59:42: warning: implicitly-declared 'constexpr BlynkTime& BlynkTime::operator=(const BlynkTime&)' is deprecated [-Wdeprecated-copy]
59 | mStop = BlynkTime(it.asLong());
C:\Users\Matte\Documents\Arduino\libraries\ESP8266WiFi\src\ESP8266WiFiSTA-WPS.cpp: In member function 'bool ESP8266WiFiSTAClass::beginWPSConfig()':
C:\Users\Matte\Documents\Arduino\libraries\ESP8266WiFi\src\ESP8266WiFiSTA-WPS.cpp:77:5: error: 'esp_suspend' was not declared in this scope
77 | esp_suspend([]() { return _wps_config_pending; });
C:\Users\Matte\Documents\Arduino\libraries\ESP8266WiFi\src\ESP8266WiFiScan.cpp: In member function 'int8_t ESP8266WiFiScanClass::scanNetworks(bool, bool, uint8, uint8*)':
C:\Users\Matte\Documents\Arduino\libraries\ESP8266WiFi\src\ESP8266WiFiScan.cpp:100:9: error: 'esp_suspend' was not declared in this scope
100 | esp_suspend([]() { return !ESP8266WiFiScanClass::_scanComplete && ESP8266WiFiScanClass::_scanStarted; });
C:\Users\Matte\Documents\Arduino\libraries\ESP8266WiFi\src\ESP8266WiFiGeneric.cpp: In member function 'bool ESP8266WiFiGenericClass::mode(WiFiMode_t)':
C:\Users\Matte\Documents\Arduino\libraries\ESP8266WiFi\src\ESP8266WiFiGeneric.cpp:442:9: error: 'esp_delay' was not declared in this scope
442 | esp_delay(timeoutValue, [m]() { return wifi_get_opmode() != m; }, 5);
C:\Users\Matte\Documents\Arduino\libraries\ESP8266WiFi\src\ESP8266WiFiGeneric.cpp: In member function 'int ESP8266WiFiGenericClass::hostByName(const char*, IPAddress&, uint32_t)':
C:\Users\Matte\Documents\Arduino\libraries\ESP8266WiFi\src\ESP8266WiFiGeneric.cpp:626:9: error: 'esp_delay' was not declared in this scope
626 | esp_delay(timeout_ms, []() { return _dns_lookup_pending; }, 1);
C:\Users\Matte\Documents\Arduino\libraries\ESP8266WiFi\src\ESP8266WiFiMulti.cpp: In function 'wl_status_t waitWiFiConnect(uint32_t)':
C:\Users\Matte\Documents\Arduino\libraries\ESP8266WiFi\src\ESP8266WiFiMulti.cpp:89:5: error: 'esp_delay' was not declared in this scope
89 | esp_delay(connectTimeoutMs,
C:\Users\Matte\Documents\Arduino\libraries\ESP8266WiFi\src\ESP8266WiFiMulti.cpp: In member function 'int8_t ESP8266WiFiMulti::startScan()':
C:\Users\Matte\Documents\Arduino\libraries\ESP8266WiFi\src\ESP8266WiFiMulti.cpp:241:5: error: 'esp_delay' was not declared in this scope
241 | esp_delay(WIFI_SCAN_TIMEOUT_MS,
In file included from C:\Users\Matte\Documents\Arduino\libraries\ESP8266WiFi\src\WiFiClient.cpp:41:
C:\Users\Matte\Documents\Arduino\libraries\ESP8266WiFi\src/include/ClientContext.h: In member function 'int ClientContext::connect(ip_addr_t*, uint16_t)':
C:\Users\Matte\Documents\Arduino\libraries\ESP8266WiFi\src/include/ClientContext.h:148:9: error: 'esp_delay' was not declared in this scope
148 | esp_delay(_timeout_ms, [this]() { return this->_connect_pending; }, 1);
C:\Users\Matte\Documents\Arduino\libraries\ESP8266WiFi\src/include/ClientContext.h: In member function 'size_t ClientContext::_write_from_source(const char*, size_t)':
C:\Users\Matte\Documents\Arduino\libraries\ESP8266WiFi\src/include/ClientContext.h:489:13: error: 'esp_delay' was not declared in this scope
489 | esp_delay(_timeout_ms, [this]() { return this->_send_waiting; }, 1);
exit status 1
Error compiling for board NodeMCU 1.0 (ESP-12E Module).
