I tried to install the local server on my mac OS computer. So far it seemed to work well. I can connect to the admin platform with my IP adress on my phone and other computers on my LAN. I also could register in the Blynk app on my local server. However, I don’t know why, I can no longer log on the server with the Blynk app. But I can still access the admin page from my phone.
I checked my firewall and it’s open. I use server-0.33.5-java8.jar
Does someone have an idea how to debug the issue? Or the issue itself?
Here’s the log:
11:09:16.111 INFO - Using data dir 'data_folder'
11:09:16.813 INFO - Region : local. Host : 192.168.0.103.
11:09:17.423 INFO - Initializing gmail smtp mail transport. Username : example@gmail.com. SMTP host : smtp.gmail.com:587
11:09:17.462 INFO - Didn't find custom user certificates.
11:09:17.465 INFO - Didn't find Let's Encrypt certificates.
11:09:17.465 WARN - You didn't specified 'server.host' or 'contact.email' properties in server.properties file. Automatic certificate generation is turned off. Please specify above properties for automatic certificates retrieval.
11:09:17.466 WARN - ATTENTION. Server certificate paths (cert : '/Users/max/Desktop/Blink_TBS_v2', key : '/Users/max/Desktop/Blink_TBS_v2') not valid. Using embedded server certs and one way ssl. This is not secure. Please replace it with your own certs.
11:09:18.266 INFO - Hardware SSL server listening at 8441 port.
11:09:18.267 INFO - Application server listening at 8443 port.
11:09:18.268 INFO - HTTP API and WebSockets server listening at 8080 port.
11:09:18.269 INFO - HTTPS API, WebSockets and Admin page server listening at 9443 port.
11:09:18.270 INFO - Mqtt hardware server listening at 8440 port.
11:15:01.685 ERROR- Wrong income message format.
11:15:29.465 ERROR- Wrong income message format.
Thanks a lot
